How Much HP on Pump Gas?
Old Mar 25, 2009 | 09:44 AM
Boostinb20!'s Avatar
Default How Much HP on Pump Gas?
I just rebuilt the Beast this year and considering staying away from C16 fuel and running strickly pump gas as this is a daily driver and weekend track toy. and alot cheaper.
Motor- B20 Vtec 84.5 mm dish Arias Pistons Eagle rods Skunk2 valve train and pro1's. Running a new precision SC6765 Billett wheel turbo. fuel is fed by dual intake walbro, to 1000cc injectors from precision. have a precision 700HP rated intercooler as well. tunning off hondata. boost controlled with Apexi AVCR.
The motor is well built and will most likely handle what i throw at it but i want to know what i will see for HP numbers on the dyno with pump ags. I ahve made 500 hp at 20 PSI with GSR cams prior with a c16/pump gas mix.
Will run as much boost as it will take too not worried.
teamoffical2010
Mar 27, 2014 05:37 AM
550whpcivic
Jun 29, 2011 09:25 PM
hondapimp125
Jan 22, 2010 06:59 PM
a1320addict
Oct 15, 2005 12:46 AM
Ri5e
Nov 2, 2003 09:54 AM
