View Poll Results: Flywheel weight
8-10#
99
39.29%
11-12#
66
26.19%
13-16#
10
3.97%
Stock Flywheel
77
30.56%
Voters: 252. You may not vote on this poll
How much does your Flywheel weigh?
Old May 4, 2009 | 05:44 PM
user 98292739's Avatar
Default How much does your Flywheel weigh?
So i am doing another swap. Right now im running an 8 lb flywheel which i dont mind. I do feel that between shifts if i am not super quick i do fall out of boost really easily. I think i want to go back to stock.
SOHC w/ greddy kit is what im running.
Old May 4, 2009 | 05:45 PM
pjr710's Avatar
Default Re: How much does your Flywheel weigh?
funny, i was just gunna post something like this... bump it up
what does everyone think the best weight flywheel for a boosted honda is? i have a boosted d16 too
Old May 4, 2009 | 05:50 PM
shawn69's Avatar
What do you mean by fall out of boost?
Old May 4, 2009 | 05:53 PM
SilverEk3dr's Avatar
Im running a CC ultra-light. Cant remember the weight prob 8lb. Running 470whp on an ls/vtec..
Old May 4, 2009 | 05:58 PM
96 GSR-T's Avatar
ACT Streetlite, think it is around 12.5lbs or so..... I have not one complaint about it.
Old May 4, 2009 | 06:15 PM
as fast as your rpm rises from the light weight flywheel it also drops just as quick not being able to have that enertia that heavier flywheels have to sustain that exhaust preassure(sorry if i worded this wrong) losing spool faster.
i been doing research for the past couple hours and thats what most say to us around 12lbs.
Old May 4, 2009 | 08:32 PM
Slink2000's Avatar
I got a spoon flywheel and its about 11lbs great for my ls/v turbo. Its good all around
Old May 4, 2009 | 09:15 PM
Muckman's Avatar
Moderator in Chief
Im running the Fidanza Flywheel. Where's the 7-8# choice?
I love it. I like that its easier to rev match and all around faster response.
Old May 4, 2009 | 09:23 PM
B16Drag's Avatar
Fidanza flywheel ~7-8lbs and loving it. I can careless about the inertia crap. I figured the crank will do a good enough job spinning the flywheel while I'm changing gears "grandma style"
Old May 4, 2009 | 11:33 PM
LSTEG96's Avatar
Traction anyone? go heavy. simple physics.
Old May 5, 2009 | 01:09 AM
91jdmhatchback's Avatar
i loved driving my old turbo probe with my fidanza flywheel. and my freinds turbo d16 drives fine and rev matches really easy with his exedy(i think) flywheel.
Old May 5, 2009 | 07:29 AM
ReDemoN's Avatar
DixielandImports Please
I have a CC 8lb flywheel on my Sohc.
Stays in boost really well actually.
I was kinda afraid is was gonna act crazy, but its fine.
Old May 5, 2009 | 08:07 AM
twkdCD595's Avatar
Not sure honestly, never weighed it by itself but I think the CC twin flywheel I have is 11-14# maybe?
Old May 5, 2009 | 08:26 AM
pjr710's Avatar
so is there any advantage of using the ligher flywheel vs teh stock one for a boosted set up?
Old May 5, 2009 | 08:43 AM
tegman23's Avatar
I love having my light flywheel ACT...I never fall out of boost...Maybe you need to shift faster lol JKJK
Old May 5, 2009 | 10:28 AM
gringotegra's Avatar
Stock here... i had a fidanza 7.5lb flywheel and i put the stock one back in and actually went faster ET's..it was on street tires and the track conditions were the same.. power was the same also... could have been driver but im not totally sure.
Old May 5, 2009 | 11:54 AM
GsrIntegra789's Avatar
I just dont see how a light weight flywheel can slow you down at all. There is plenty of other weight on the crank to keep the inertia. The pressure plate is heavy as hell too. If you think about it, i dont think the motor will gain more top end. However, it should release more wtq in the mid range rpms since its alot more easy to spin that crank?? I know this is a subject that has been debated for years with no real answers. (just like the b16 vs gsr head debates) Someone needs to dyno a stock motor with a stock flywheel and then dyno it again in the same weather conditions with a light one. Then you can compare the power curves.
Old May 5, 2009 | 12:56 PM
Muckman's Avatar
Moderator in Chief
This subject has been covered a million times. It doesnt make much difference either way. Its more about driving preferance than performance.
Redemon said it best - Everyone thinks its going to be insane and its not a big deal.
All im saying is that was my experence with the light flywheel on my car.. it was about 320whp at that time..and i Went FASTER with the Stock one...maybe it was driver maybe it was the car i dont know, all i know is after i put the stock one back in i went faster ET wise... Here is a thread that has a lot of info on Light flywheels, i also posted lots of 1/4 mile info on it... I had Back to Back weekends where i went out and raced and went faster :
https://honda-tech.com/forums/showth...light+flywheel
Old May 5, 2009 | 04:50 PM
B16Drag's Avatar
gringotegra, I think it was the driver
Honestly, I dont think it matters which one you go with... I just went with the Fidanza because I had an extra one laying around and buying the lil metal insert was like $30 more than getting the stock flywheel resurface...
I'm sure either way it will be just fine.
Old May 5, 2009 | 05:57 PM
im not sure man, all i know is i consistantly went faster with the Stock flywheel...look in that thread i posted pages 4 and 5 i posted all the info i could....
im not doggin on either one... as far as i know all the Real race cars have light ones...i think there is a fine line between too light and just right for each setup..
Old May 6, 2009 | 02:20 PM
awesome cause i was thinking about this too.
I know heavier = less easy to wheel spin.
Right now with my 8# i spin VERY easily in 1st.
so i guess its 50/50 its only 60 for a OE replacement which was what i was going to buy to replace my 8# now im not so sure.
Old May 6, 2009 | 02:32 PM
4drEF's Avatar
Keyboard Humorist
If you are falling out of boost with a lighter flywheel then shift faster?
You are letting your RPM drop too low between shifts - that's the only thing slowing you down.
Old May 6, 2009 | 03:38 PM
Schister66's Avatar
Man U FTW
I had an ACT 11lb fly with my previous setup. Now i have a stock LS Fly on my current setup. I'll give up a few revs in order to boost earlier in the rpm range...my turbo is going to need all the help it can get for a street application
Old May 6, 2009 | 09:13 PM
ef9civicgen4's Avatar
whatever a flywheel for an exedy twin disk setup weighs???
