How much boost on import builders package 4
How much boost on import builders package 4, heres wut its got.
Package 4: Hydro LS "TURBO"
Comes with bran new axles, shift linkage, ECU, wire harness, stock mounts, complete motor. Tranny included.
This is a HIGH PERFORMANCE total rebuild package for those of you that are sick of getting used motors that don't last. This package includes Import Builders completely revamping the motor. Golden Eagle Sleeved block, New JE Forged Pistons 84MM, new Eagle Rods, balanced crank, new bearings (all), new oil pump, new water pump, new timing belt, new alternator belt, new high performance valve train, new high performance cams, CM flywheel, new adjustable cam gears, Hondata Stage 2, OBD1 ECU, new valve seals, new head gasket, new valve cover gasket, and new 6 puck Hyper clutch with new bearing. Turbo setup as follows: T03/4, Spearco intercooler, Custom piping (IB), HKS wastegate, Blow off valve, Custom 2.75 inch down pipe (NO A/C), High flow Cat 3", Oil pressure gauge, Boost gauge, Gauge pod, All fittings, RC 550 CC injectors, Hondata Stage 2b, Shipping included
I'm goin to be taking my boost up to about 25psi. The motor should be fine, it all will come down to your fuel management.
It aint **** if it doesnt come with an EGT gauge. If it had that I would say it will easily push over 5 psi.
EDIT* Sorry, I had to say something dumb.
But really, why ask us. If you are serious about buying this motor, why dont you just ask them?????????????
[Modified by 93LSivic, 12:07 AM 5/8/2002]
94lsboost
Nov 24, 2004 12:46 PM
2.2L EH2
25
Jun 25, 2002 07:56 PM
