How much boost can a D16 take with...
Old May 13, 2003 | 10:27 PM
hatchback's Avatar
Default How much boost can a D16 take with...
JE Pistons, Eagle Rods, and sleeves..
also, what kind of sleeves do you guys recommend? Also do you recommend any special machine work?
Old May 13, 2003 | 10:35 PM
extrmeboost's Avatar
Default Re: How much boost can a D16 take with... (hatchback)
1 miiilliiion pounds
id say as much as youre fuel system can handle, but realisticly 25 psi
Old May 13, 2003 | 10:37 PM
Default Re: How much boost can a D16 take with... (extrmeboost)
golden eagle all the way
Old May 13, 2003 | 10:48 PM
turbo_ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extrmeboost &raquo;</TD></TR><TR><TD CLASS="quote">1 miiilliiion pounds
hehe^^
Old May 13, 2003 | 11:05 PM
hatchback's Avatar
Default Re: How much boost can a D16 take with... (eli_vang)
Anyone recommend a certain kind of sleeves?
Old May 13, 2003 | 11:10 PM
Midwestrider's Avatar
Some like GE, some like Darton...
Talk w/ TurbodCX he has GE's in his D16..
Good luck..
Old May 14, 2003 | 07:23 AM
hatchback's Avatar
Default Re: How much boost can a D16 take with... (Midwestrider)
thanks
Old May 14, 2003 | 07:51 AM
boosted hybrid's Avatar
I recommend and use GE sleeves. I have had three blocks from GE in the past two years, all with success. Warrenty, customer service and a well engineered design always go well in my book.
Old May 14, 2003 | 08:21 AM
TurboSedan's Avatar
New User
Default Re: How much boost can a D16 take with... (boosted hybrid)
I would go with GE!
Old May 14, 2003 | 08:46 AM
TurbodCX's Avatar
Default Re: How much boost can a D16 take with... (TurboSedan)
I use GE in my D-series and i have seen 20psi with no problems, and plan on going to 25 soon..
Brian
Old May 14, 2003 | 09:59 AM
*Boostwerks*'s Avatar
It's not about boost.
It's about HP/tq.
with that being said, you can boost what ever you want as long as the turbo is running around 70% efficency, and your making under 500whp...
Old May 15, 2003 | 09:30 AM
hatchback's Avatar
Default Re: How much boost can a D16 take with... (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">It's not about boost.
It's about HP/tq.
with that being said, you can boost what ever you want as long as the turbo is running around 70% efficency, and your making under 500whp... </TD></TR></TABLE>
So how do I find out how effecient the turbo is running? Through dyno tuning?
Old May 15, 2003 | 09:35 AM
94dxt's Avatar
generally speaking how much power can stock d16z6 sleeves handle?
Old May 15, 2003 | 06:34 PM
TurboSedan's Avatar
New User
Default Re: How much boost can a D16 take with... (94dxt)
I would say around 15psi with proper tuning.
Old May 15, 2003 | 07:43 PM
Compressor map.
A 60 trim T3/TO4E with .63ar would make very good power on a built D series.
I'm going with a 50 trim .63ar for my 400hp ZC. I love it's compressor map! 75%ish efficency up to around 33psi!
Old May 15, 2003 | 07:57 PM
norcalcrx's Avatar
Im running 10psi daily on my completely stock internal d16z6. Im going to be tuning for 15 psi here in the next few weeks.
Mr. K20addict
147
Mar 24, 2008 10:04 AM
1FSTNDN
12
Dec 19, 2006 07:56 PM
Boost_jnky
Apr 29, 2005 04:41 PM
prestoned
27
Dec 8, 2003 07:32 AM
