how many psi?
Old Oct 17, 2008 | 02:47 PM
jdmkid_82's Avatar
Default how many psi?
i believe the smallest greddy kit turbo is a 15g? if fo. how many psi can it push
Old Oct 17, 2008 | 03:03 PM
RC000E's Avatar
Default Re: how many psi? (jdmkid_82)
Old Oct 17, 2008 | 04:09 PM
HiProfile's Avatar
Actually the D-series kit is the 15g, and the B-series kit is the 18g. The 15g from Greddy is similar to a 50trim T3, except it has a smaller turbine. 250whp would be pushing that small turbo, and could fail quickly at the shaft speeds required for that.
The problem is the Greddy elbow included will not let you get near the turbo's limit. Its very restrictive with a very tight bend. Due to this and the WG design, 15psi is about as much as you'd want to get from this turbo.
Monkey Z.
Sep 15, 2005 03:43 AM
Big_Bird
Oct 30, 2003 05:51 PM
GorData
Jun 25, 2003 10:59 PM
blazin99si
Mar 12, 2003 02:52 PM
