How to make GSR a 2.0L??
Old Feb 9, 2003 | 06:39 PM
speedy108's Avatar
Default How to make GSR a 2.0L??
What size bore does a GSR block need to have 2.0L? 84.5?
And will I still be able to rev it to 8500 rpm?
Thanks.
Old Feb 9, 2003 | 06:41 PM
greddyturboGSR's Avatar
Default Re: How to make GSR a 2.0L?? (speedy108)
I am kinda interested as well, when it comes time for a re-build I was thinking of doin the same.
Old Feb 9, 2003 | 06:42 PM
ImportReview
Guest
Posts: n/a
84.5+ by straight definition.
Old Feb 9, 2003 | 06:48 PM
Default Re: How to make GSR a 2.0L?? (ImportReview)
How does this affect cylinder wall strength, The most boost I would be running in the future should be around 14 psi. will i still be safe?
Old Feb 9, 2003 | 06:51 PM
J2turbo21's Avatar
Default Re: How to make GSR a 2.0L?? (greddyturboGSR)
One more mm and my block would be a 2.0
C-Murdock's Avatar
why not just get a B20 block ?
justagsr's Avatar
GE conversion plate kit. I know there has been a post about this before.
Old Feb 9, 2003 | 07:02 PM
Default Re: How to make GSR a 2.0L?? (C-Redrum)
Im not really familiar with swapping motors and what heads bolt onto which blocks, but if a b20 block bolted up on my GSR then it seems like alot less trouble doing that to get a bore of 2.0 then boring my gsr block.
Old Feb 9, 2003 | 07:11 PM
BudaKai's Avatar
That is until your sleeves crack.
Old Feb 9, 2003 | 07:36 PM
SiRkid's Avatar
Default Re: How to make GSR a 2.0L?? (BudaKai)
yup
Old Feb 9, 2003 | 07:39 PM
boostaholic's Avatar
The b20 sleeves seem weak enough already, i wouldn't overbore them without sleeving first. You can also swap in the ls crank and rods in a gsr block and bore that out to 84mm to get a 2.0L as well.
Old Feb 9, 2003 | 07:54 PM
boosted hybrid's Avatar
Default Re: How to make GSR a 2.0L?? (boostaholic)
The 84.5mm bore will make it a solid 2.0L. My is sleeved and bored to 84.5mm.
Old Feb 9, 2003 | 07:59 PM
J2turbo21's Avatar
Default Re: How to make GSR a 2.0L?? (boosted hybrid)
Can any aftermarket sleeve take an 84.5mm bore?
Old Feb 9, 2003 | 08:07 PM
Default Re: How to make GSR a 2.0L?? (J2turbo21)
GE, darton, rs, etc they can all take it. The 84.5mm is the largest you can go and be safe with the thickness of the sleeve.
Old Feb 9, 2003 | 08:13 PM
J2turbo21's Avatar
What sleeves do they use at bensons?
Old Feb 9, 2003 | 08:22 PM
AVATAR's Avatar
Cant you go 86mm? Not that it would be safe, but isnt that the max bore size GE recommends.
Old Feb 9, 2003 | 08:28 PM
TREVER's Avatar
85.5= 2.0l
the bore doesn't affect the ability to rev to 8500
Old Feb 9, 2003 | 08:31 PM
ninesecrx's Avatar
Default Re: How to make GSR a 2.0L?? (TREVER)
bore size does affect the ability to rev cause of piston mass.
Darton sleeves made to Benson's specs. Atleast that's what i was told when i had my gsr block sleeved there.
Old Feb 9, 2003 | 08:37 PM
_______
What would the rev limit be on a GSR block bored to 2.0?
Old Feb 9, 2003 | 08:39 PM
J2turbo21's Avatar
I know my gsr motor can rev to 10k with an 83.5mm bore.It has been taken to 9600rpm.
Old Feb 9, 2003 | 08:46 PM
bretx0r's Avatar
because they SUCK
Old Feb 9, 2003 | 08:47 PM
I Like Boost's Avatar
If the head is stock dont take it over 8200 rpm. if the head is built than it depends on the quality of the rods/pistons/who built the engine. it really depends on alot of things mostly tuning and what parts where changed. i plan on takeing my 84mm b18c to over 9000 rpm with 24+ psi of boost.
Old Feb 9, 2003 | 09:19 PM
Pelican's Avatar
Default Re: How to make GSR a 2.0L?? (IMPULSE B18C-T)
So true. Just because your motor had been to a sky-high RPM, doesn't mean it won't die there
Old Feb 9, 2003 | 10:08 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: How to make GSR a 2.0L?? (Pelican)
almost any properly built head will allow the motor to rev successfully to 10k but making power up there is another story.
