how long do walbro's last??
debating taking the walbro out of my old car and putting it into my new turbo car. the pump has around 20-25k miles on it. do these have a lifespan or is it similar to a stock pump? ive never run the car empty or below 1/8 tank, cus i know they can get hot with no gas around them to dispurse the heat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWDstylez »</TD></TR><TR><TD CLASS="quote">I've known people have had them in their cars for 30-40k+. I've had mine (255HP) in my car for 4 years and 30k and it still works perfectly.</TD></TR></TABLE>
They will last as long as a stock pump.
my walbro didnt die...but it couldnt hold its pressure once i got into boost, it had about 40k mi on it.
threw in another 255hp that was on a car making 600+whp and that one leaned out on high boost 23+psi...
i havnt had too much luck with em
hopefully the boschs wont give me problems
It depends on what type of abuse the pump was subjected to... Obviously higher fuel pressures would mean more heat, wear and tear and shorter lifespan.
Watch out for knock off Walbro pumps that seem to float around on Ebay recently...
My walbro has been used for a long long time; I had it when I was all motor back in '99... I am still on the same pump and it still runs like a champ after 7 years and over 90000 miles...LOL My rail pressures are constantly above 50 psi during idle, and up to 70 during boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 »</TD></TR><TR><TD CLASS="quote">for the price why not just buy a new one</TD></TR></TABLE>
and sell your used one on ebay
except when the walbro leans out on u and melts your pistons
ask me how i know
ask me how i know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly »</TD></TR><TR><TD CLASS="quote">ask me how i know </TD></TR></TABLE>
I hate it when people say that. Why don't you just tell us? Also, there doesn't seem to be a good alternative for an in-tank pump. I'd get a Bosch, but it seems like a pain in the ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets »</TD></TR><TR><TD CLASS="quote">
I hate it when people say that. Why don't you just tell us? </TD></TR></TABLE>
cuz it leaned out on me and i melted a piston...lol, figured it was pretty self explainatory
cuz it leaned out on me and i melted a piston...lol, figured it was pretty self explainatory</TD></TR></TABLE>
Why don't you give a little more information!!
Like: fuel pressure, FPR, boost level? If you were running high fuel pressure levels you can only blame the idiot who did the wrenching and not the pump. It is COMMON KNOWLEDGE that Walbro's do not like high fuel pressure levels. Or maybe you were trying to make a single Walbro support a HP goal that was not within it's range? Provide more info or STFU
Oh yeah, I have been using a Walbro pump since '01 with no problems.
Modified by Dee at 11:51 PM 2/19/2007
I guess that's why I hate it. You already told us what it did, but left us with the anticipation of reading something so spectacular, that we had to first ask permission for said information.
* Does anyone else have and issue with their walbro's make'n some noise pretty loud when they get real low on fuel??? mine does but soon as i put gas its fine so...? was thinkin of gettin another to be safe but it still is capable of 100+ lbs of FP.
I was just about to buy a walbro and wanted to get this one from the german E-bay, since i'm in Europe.
Can anyone tell if it's a knock off?
Walbro 255 pump
Walbro 255 pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls »</TD></TR><TR><TD CLASS="quote"> * Does anyone else have and issue with their walbro's make'n some noise pretty loud when they get real low on fuel??? </TD></TR></TABLE>
every one ive ever seen gets a lil noisy when low on fuel
well mine is dead i have had it for about 4 years and 40k but the thing has had a over heat issue for about 2 years where if the tank was 1/4 i better not shut the car off the pump would not start back up.
and that is a problem with at small tank that is in a HF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JrCRXHF »</TD></TR><TR><TD CLASS="quote">well mine is dead i have had it for about 4 years and 40k but the thing has had a over heat issue for about 2 years where if the tank was 1/4 i better not shut the car off the pump would not start back up.
The symptoms you've described sounds more like a wiring issue instead.
The pump constantly cools as it pushes fuel... In order to physically overheat the pump to the point of "locking up" momentarily, your fuel temperature must be like 500+ deg F
A wiring issue (bad ground, too much resistance from under-gauged wires, etc) would cause electrical compents to heat up and momentarily loses its function.
