How to install a Harmonic Damper by Fluidamper
Old Apr 7, 2004 | 02:02 PM
  #26
hybrid901's Avatar
Default Re: (Bryson)
I got mine from Art and he had it to me overnight for a race.
Old Apr 7, 2004 | 02:23 PM
  #27
m R g S r's Avatar
Default Re: (hybrid901)
This is a part that is going to be one my engine before it even starts up. Thanks for the install info art. And yellowturbo, the unorthodox pulleys will probally hurt your motor when you rev it that high, because they don't have a balancer in them like the stock ones.
Old Apr 7, 2004 | 03:34 PM
  #28
Nextelbuddy's Avatar
Default Re: (jerseykid609)
so when you get one of these and you install it.. is there any adjusting you have to do or is this simply a bolt on affair?
Old Apr 7, 2004 | 04:09 PM
  #29
CheezeFrog's Avatar
Default Re: (arturbo)
Do they come in any other colors? j/k Good stuff, Art. I need me one of those.
Old Apr 7, 2004 | 04:41 PM
  #30
JDMH22HATCH's Avatar
Default Re: (CheezeFrog)
Great write up Art. I'll be getting ahold of you as well shortly.
Brandon
Old Apr 7, 2004 | 09:41 PM
  #31
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: How to install a Harmonic Damper by Fluidamper (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Art, can you use the balancer with the alternator pulley and the crank trigger wheel addition at the same time?</TD></TR></TABLE>
Yes, the crank trigger is on the oppisite side of the alternator pulley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">please explain how that crank trigger works. Where is the sensor/trigger?
I suppose you are too good to mod the distributor? </TD></TR></TABLE>
Ben, the pick ups and sensors are not yet mounted. Good eye!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">
Do they come in any other colors? j/k Good stuff, Art. I need me one of those.</TD></TR></TABLE>
They come in pink just for you...lol
art
Old Apr 8, 2004 | 03:00 AM
  #32
PrecisionH23a's Avatar
Default Re: How to install a Harmonic Damper by Fluidamper (Arturbo)
I would like to see a Type R yellow damper. That's extra points at the big car shows! I sent an email to fluidamper reguarding the realease date of the H series product, I will make sure and fwd this info onto you guys when I find something out.
As far as the H series dampers are concerned, that is going to make pulling/installing the motor that much more trickier depending on the dimensions of the damper. Fitment issues in the prelude are a lot different then they are in a nice little hatchback.
On the other hand, I would like to give larry props for the dyno and shop, very sexayy I'm so jealous of you art. Oh ya, tell him to answer his damn phone this morning!
On the other hand, when having your bottom end balance will also help to reduce the harmonic vibrations as well due to a more uniform reciprocating assembly, correct?
Old Apr 8, 2004 | 03:47 AM
  #33
doublej's Avatar
Art,
Great writeup. Just received my order and Fluidamper has machined the back of the damper to clear the plastic belt guard. Nice product, nice people.
While at vmp, please stop by Jason's and introduce yourself.
thanks,
Jim
Old Apr 8, 2004 | 03:52 AM
  #34
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: How to install a Harmonic Damper by Fluidamper (doublej)
Jason Hunt?
I just sent some out with the machined backing, but we still advise to cut it just in case..hehe People might freak out when they see smoke. Fred at fluidamper is a really nice guy..
art
Old Apr 8, 2004 | 04:09 AM
  #35
doublej's Avatar
Yes, Jason Hunt. Look for some old fart putting in/taking out air in tires. That's me.
Old Apr 8, 2004 | 11:52 AM
  #36
It looks like the H series dampers will not be available till late 2004
Old Apr 8, 2004 | 10:17 PM
  #37
ki11a8ee's Avatar
Default Re: How to install a Harmonic Damper by Fluidamper (PrecisionH23a)
man that would suck if the h22 one came out later. all the b series motors are spoiled with aftermarket parts. Let us know when it will come out art?
Old Apr 9, 2004 | 05:31 AM
  #38
Dublocivic's Avatar
I am going to need one.. Nice product and great write up Art.
Old Apr 9, 2004 | 09:43 AM
  #39
slowsi00's Avatar
group buy.
Old Apr 9, 2004 | 11:07 AM
  #40
hpfsi's Avatar
Default Re: (slowsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsi00 &raquo;</TD></TR><TR><TD CLASS="quote">group buy.
Old Apr 9, 2004 | 01:49 PM
  #41
Default Re: (nextelbuddy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">so when you get one of these and you install it.. is there any adjusting you have to do or is this simply a bolt on affair?</TD></TR></TABLE>
bump?
Old Apr 9, 2004 | 04:06 PM
  #42
Big Teggie's Avatar
Default Re: (JDMH22HATCH)
Nice work Art
I have been meaning to get a Fluiddamper, maybee do a review on it too.
Old Apr 9, 2004 | 04:34 PM
  #43
Smashback's Avatar
Default Re: How to install a Harmonic Damper by Fluidamper (Bnjmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bnjmn &raquo;</TD></TR><TR><TD CLASS="quote">Off topic-
Since I assume this is on an OBD1 engine, I also assume the crank trigger is for DIS.
Damn, I'm surprised these things aren't way more expensive. Not that I can afford one any more than I could 10 years ago, but still, I'd have guess in the $600 neighborhood rather than $350!
Old Apr 9, 2004 | 04:41 PM
  #44
damn can no one answer this question.. i searched for this and found no help i am realyl thinking abuot this item to preserve my bearings and oil pump the most but i need to know this
Old Apr 9, 2004 | 08:05 PM
  #45
Arturbo's Avatar
Better than steak
25 Year Member
Its just a bolt on. the pics show you that you need to cut the plastic cover, that was the purpose of this post.
art
Old Apr 9, 2004 | 08:40 PM
  #46
Default Re: (Arturbo)
oh ok. the only reaso i asked was because i noticed degree marks on it and i wasnt sure if that was for adjusting timing or if it had a dual purpose as far as adjusting the dampner to cater to every different kind of motor setup since not everyone uses the same bearings and many people have micropolished cranks and possibly knife edged which coudl throw off teh balance as well but if this is just a bolt on dampner then thats cool
Old Apr 11, 2004 | 11:28 AM
  #47
m R g S r's Avatar
That's the point of the balancer, is to absorb different vibrations that every motor puts out, unlike the stock one, which art mentioned, is only meant to absorb vibrations from stock internals.
Old Apr 21, 2004 | 06:40 AM
  #48
GreasGun's Avatar
Default Re: How to install a Harmonic Damper by Fluidamper (Gravy)
Dyno testing results from the ATI site:
http://www.atiperformanceprodu...s.htm
Old Apr 21, 2004 | 07:02 AM
  #49
CheezeFrog's Avatar
When are the A/C compatible ones coming out?
Old Apr 21, 2004 | 07:44 AM
  #50
ladysman's Avatar
Default Re: How to install a Harmonic Damper by Fluidamper (CheezeFrog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">When are the A/C compatible ones coming out? </TD></TR></TABLE>
Better yet, D series AC one.
