how important is r/s ration in boosted engine
Old Jun 30, 2009 | 05:58 AM
jspeceg's Avatar
Default how important is r/s ration in boosted engine
caught up in the r/s ratio debate. on my current build i have a r/s ratio of 1.49 in a gsr block. i have heard that 1.75 is ideal and have a line on a different crank (which would require different rods obviously) that would give a r/s ratio around 1.67. so do i roll with what i have or look to change? i would be giving up about .2 liters in the process which i dont really care about.
is a 1.49 r/s ratio safe (and reliable) for a daily driven supercharged vehicle?
Old Jun 30, 2009 | 07:45 AM
raene's Avatar
Default Re: how important is r/s ration in boosted engine
Forget about rod/stroke ratio. Focus on keeping a lower redline with a bigger displacement and make more reliable power. High redline kills parts. R/S ratio has to be the most overrated (in terms of importance) spec of an engine.
Old Jun 30, 2009 | 01:47 PM
Schister66's Avatar
Man U FTW
Originally Posted by raene
Forget about rod/stroke ratio. ... R/S ratio has to be the most overrated (in terms of importance) spec of an engine.
I agree. Honestly, this is something i've never even considered while building a setup for FI
Old Jul 1, 2009 | 11:44 AM
jspeceg's Avatar
ok. thanks!
Old Jul 1, 2009 | 08:00 PM
solo227's Avatar
its more important in smaller engines...B16s when going all motor...
Cuz your trying to spin the motor higher than it was built to go... Its only gonna matter in a engine thats revving to 10k+
Old Jul 1, 2009 | 09:34 PM
Tony the Tiger's Avatar
Unless you are greedy, and you want a turbo that spools around 5000RPM with a useable redline of 10000RPM, just like my Integra. That's when I think R/S is important, but to a regular guy, it may not mean anything.
Old Jul 1, 2009 | 11:25 PM
locash's Avatar
Screw the R/S ratio. We run the 84mm bore B18 motors to 10500 all the time, with 30-50 psi boost. They aren't coming apart from over-revving. Keep in mind, these are drag cars, not daily drivers..
tundra2000
Sep 28, 2010 06:34 PM
jbell
Oct 18, 2009 10:32 PM
prdtr15
Sep 27, 2003 02:27 AM
boosted3g
Jan 9, 2003 02:28 PM
racerxadam
Jul 30, 2002 09:55 AM
