How I modify this turbo?
Old Feb 6, 2004 | 12:10 PM
95lsteg's Avatar
Default How I modify this turbo?
I have a Turbonetics t3/t4, with a .48 turbine and .60 compressor.
How difficult is to modify the turbine to make it something like .60 or .63 ?
I was told that just have to change the housing.
Old Feb 6, 2004 | 12:12 PM
0x64Work's Avatar
Default Re: How I modify this turbo? (95lsteg)
Buy a .63 turbine housing from Turbonetic's or exchange your housing for a .63 A/R housing with Turbonetic's. I have switched back and forth from .48 A/R to .63 A/R a couple times with a Precision turbocharger.
Old Feb 6, 2004 | 01:16 PM
spoolinlude's Avatar
I live under a rock
Default Re: How I modify this turbo? (0x64Work)
When rebuilding the turbo after swapping out your housings, just make sure to replace the o-rings....... sometimes the compression/decompression can cause a bad seal...... you can get these from turbonetics etc....... in some cases you may not even have to mess with removing them.......
Old Feb 6, 2004 | 04:34 PM
95lsteg's Avatar
So, the wheel remains the same, right?
theEGkid
Sep 22, 2005 10:44 AM
elpiar
Sep 18, 2005 10:12 PM
Honda Sport
Jul 16, 2004 04:58 PM
booscivic
Dec 15, 2003 07:14 PM
4U2NV
Dec 29, 2002 11:06 AM
