how to get circlip down
Old Nov 15, 2003 | 08:57 AM
ironcheftony's Avatar
Default how to get circlip down
i got a 14b turbo and i need to put the circlip back on, i got it on, but it wont go all the way down competely to settle in its groove, is there any technique or easy way to get it in ?
Old Nov 15, 2003 | 09:07 AM
Johnyquest's Avatar
Default Re: how to get circlip down (ironcheftony)
I got the NASTYIEST blood blister trying to do that exact same thing on an hks ssqv. It took me like 3 hrs. Compress it really good, make sure your putting it on the right way (is one side tapered?), and if you can't do it, have someone use a regular screwdriver to try to seat it as you hold it.
Lastly, make sure your turbo is properly seated-- ie make sure there isn't any crap making it sit a bit high-- wipe the mating surfaces clean.
Old Nov 15, 2003 | 02:01 PM
thanx, i got most of it on i think, hopefully it doesnt fly off again
Old Nov 15, 2003 | 02:32 PM
Evil EG's Avatar
Default Re: (ironcheftony)
theres a tool you use for it. it looks like pliers but at the end it has to little pins on it that go in the clip so you can squeeze it together. The local auto store should have one.
Old Nov 15, 2003 | 02:37 PM
rjardy's Avatar
Default Re: (BVM)
yes, they are called c clip pliers, you can get a nice craftsman set at sears for about 25 dollars. It will save you the blood blisters
Rob
grjp1988
May 31, 2007 01:41 AM
RuskeR
Jul 20, 2005 11:35 PM
Jamez
Welding / Fabrication
Jun 25, 2005 03:00 PM
DSC
Feb 18, 2003 01:19 AM
GSR1ner
Jul 19, 2001 08:55 PM
