How to check for continuity when installing resistor box?
Old Apr 19, 2008 | 11:30 AM
totsie7944's Avatar
Default How to check for continuity when installing resistor box?
Hey I know its been covered guys but my hands are full of grease from installing this turbo kit and I need to get it done while the suns out....don't have time to be searching and reading.
What tool do I need to check for continuity? I understand how to wire the box in, just not how to make sure which 4 wires I need to run to the resistor box.....thanks.
I went to radioshack and bought a volt and ohm reader but my friend says she doesn't think that will work....let me know.
Old Apr 19, 2008 | 12:36 PM
IN VTEC's Avatar
Default Re: How to check for continuity when installing resistor box? (totsie7944)
You can use the ohmmeter. If it has a measureable resistance, then there's continuity. A digital meter will work better than an analog because the analog may not have the resolution to move the needle.
I recommend the auto-ranging multimeter from Sears. It's only $30 and it has a continuity tester that makes an audible beep when there's continuity and it's auto-ranging so you don't have to fiddle with the dial. The leads are junk and like to pop out of the box sometimes. They're also a bit short for some things that I need it for.
Old Apr 19, 2008 | 05:10 PM
totsie7944's Avatar
Default Re: How to check for continuity when installing resistor box? (IN VTEC)
ok dumb question, but Are you saying that I can set it on the OHM side of the meter and that just the wire itself will produce some sort of resistance? and thats how I tell when I'm touching the pin that corresponds to the injector plug I'm touching?
Old Apr 19, 2008 | 06:58 PM
IN VTEC's Avatar
Yes. But the meter has to be able to register that small amount of resistance. It will probably be in the tenths to hundredths of ohms.
slowesteg
Feb 2, 2012 01:35 PM
jne
Feb 8, 2010 10:23 AM
makeustruggle
Dec 11, 2008 06:38 PM
z6
Jun 19, 2004 06:37 PM
TokuiAutowerks
Jun 11, 2003 07:59 AM
