How Can I Make This FIT!!
Guest
Posts: n/a
Got my manifold in tuesday, started installing everything and ran into this.
Already removed the front motor mount
How is the 3" downpipe going to fit!? does anyone have pictures of the full race h22 manifold so i can get an idea, the pics in the thread are down.
w/o front motor mount
Modified by john d at 9:21 AM 12/22/2004
fit the 3" pipe through the largest opening. looks like you gonna need some real tight radius bends and prob route the DP about 120 degrees to go towards the opening and that should be cool.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP »</TD></TR><TR><TD CLASS="quote">wow .. i have no idea .. is this in a CRX?</TD></TR></TABLE>
looks like a lude.
looks like a lude.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote"> fit the 3" pipe through the largest opening. looks like you gonna need some real tight radius bends and prob route the DP about 120 degrees to go towards the opening and that should be cool.</TD></TR></TABLE>
that would work if the turbo wasnt damn near sitting on the cross member.
looks like a lude. </TD></TR></TABLE>
yes its a 5th gen prelude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 »</TD></TR><TR><TD CLASS="quote">Get a slim fan and make a side exit exhaust.
good idea, but the motor mount would be in the way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itrboy »</TD></TR><TR><TD CLASS="quote">try to get a refund...hopefully cody will do it...</TD></TR></TABLE>
yeah, im pretty sure he'll give you the money back. but damn that sucks to have to wait, sry to hear man
looks like u gonna need some exhaust donuts to make it work. or get a plasma cutter and **** up that corssmember !@!!$&#@*( tear that sht up !
I think it could be done, like stated above all you will need is a couple of 3" exhaust donuts and or some tight radious bends.
Btw why do I see a 35mm wg flange on that manifold with a T4 turbo on it, besides that how are you gona fit a wastegate there considering your still running a full radiator core??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSturboEH2 »</TD></TR><TR><TD CLASS="quote">slim fan, a little hacking off that lip on the lower member, and some tight bends. itll work. fabrication is half the fun
dont even think that will work, it'd have to be something really crazy and he'd have to remove the front motor mount which is a no no
</TD></TR></TABLE>dont even think that will work, it'd have to be something really crazy and he'd have to remove the front motor mount which is a no no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trac226 »</TD></TR><TR><TD CLASS="quote">Crossmembers are for pussies,
, I'd start shaving it down until you can fit some tight turns in there.</TD></TR></TABLE>
look how far he'd have to shave off of it. he'd even have to shave into the block for it to even work
, I'd start shaving it down until you can fit some tight turns in there.</TD></TR></TABLE>look how far he'd have to shave off of it. he'd even have to shave into the block for it to even work
the lower lip alone will not work, he'd have to cut into the block (not just the webbing part, but the actual block) and thats with no front motor mount, look at the pictures above
Modified by nlc at 3:19 AM 12/22/2004
</TD></TR></TABLE>the lower lip alone will not work, he'd have to cut into the block (not just the webbing part, but the actual block) and thats with no front motor mount, look at the pictures above
I can help you out..I had to go thru the same **** with a lovefab sst on a 97 lude..I will post some pics tomorrow of what I did to clear it..doesnt look the best but the car did make over 600 whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch »</TD></TR><TR><TD CLASS="quote">I can help you out..I had to go thru the same **** with a lovefab sst on a 97 lude..I will post some pics tomorrow of what I did to clear it..doesnt look the best but the car did make over 600 whp.</TD></TR></TABLE>
would like to see it
did you still run a front motor mount?
3" dp?
t4 exhaust housing?
3" dp?
t4 exhaust housing?
have fun w/ that...we just finished up doin my friends prelude dp....
we cut the motor mount....shaved off the lip on the lower crossmember, and some off the block...not to much tho....and alot of cutting, tack welding...and fishing into place...we finally got the 3" dp in there....but not w/o a lot of work
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch »</TD></TR><TR><TD CLASS="quote">yes yes and yes..pics will come later today..but once you see it you will understand..but you will need a half size civic radiator to do it..</TD></TR></TABLE>
exactly, you need a 92-95 civic radiator, and looks like you will have to run the down pipe forward of the crossmember
okI know what its like to need help and have someone lag on you so here you go sir..basicly its standard stuff from a local bolt house and a piece of 3 1/2 inch 1/8 inch thick pipe cut in half that goes under the subframe in (where we cut it out out) to add durablity to it..car has seen lots of low 11 second pass's and 3 10 second pass's..ok enough of the BS here are the pics..
That, or get the sawzall out so you can use the downpipe that was made with the manifold.
Weld some sheetmetal in wherever you cut to add some strength back in.
Sorry for any confusion, the new site mentions this too btw.
Modified by Tinker219 at 9:05 AM 12/22/2004
