How to calculate compression ratio?
Old Jun 29, 2002 | 02:39 PM
Ltech's Avatar
Default How to calculate compression ratio?
I have b16 block with 84 bore and 77 stroke, 0.036 head gasket, open combustion chamber to match 84 bore and 9:1 pistons. what is the formular to find Combustion Chamer Volume, Piston Dome displacement? I;m probably in the 8.
jason phan
Old Jun 29, 2002 | 02:42 PM
speeds's Avatar
Default Re: How to calculate compression ratio? (Ltech)
go to http://www.c-speedracing.com/howto/
Old Jun 29, 2002 | 04:35 PM
Ltech's Avatar
Default Re: How to calculate compression ratio? (speeds)
I have the web page. As you can tell I change the bore, combustion chamber and pistons compression. I'm interested in finding Combustion Chamer Volume, Piston Dome displacement. So I can plug them in to find out my C/R.
Old Jun 29, 2002 | 04:52 PM
2K_TEG's Avatar
just use the stock combustion chamber volume for whatever head you are running. Unless you get your cumbustion chambers cc'ed this is your best bet. Piston dome displacement should be on the spec sheet that came with your pistons.
Old Jun 29, 2002 | 05:40 PM
ninesecrx's Avatar
If you don't know your numbers, we can't figure it out for you either. That c-speed link works perfect. Just drop in the numbers
Old Jun 29, 2002 | 05:52 PM
Ltech's Avatar
Default Re: How to calculate compression ratio? (ninesecrx)
I guess I have to find out the formular for myself.
Old Jun 29, 2002 | 06:16 PM
earl's Avatar
The formula is simple. Cylinder volume at BDC divided by cylinder volume at TDC. It's calculating those volumes that makes the c-speed link awsome USE THE LINK
Old Jun 29, 2002 | 07:41 PM
Ltech's Avatar
Default Re: How to calculate compression ratio? (earl)
Got it thanz Earl.
dc2-millano-red
14
Jan 1, 2014 05:48 AM
Spawne32
Sep 26, 2010 10:45 AM
guy_from_nerk
Feb 5, 2009 09:12 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
1.8EG-T
Feb 12, 2005 06:58 PM
