Hood Venting for a turbo
Old Sep 26, 2001 | 06:31 PM
revhrdls's Avatar
Default Hood Venting for a turbo
Would it actually help to have a vented good for the sole purpose of hot air escaping your engine? I ask because I might actually vent my hood sort of like the predator style to vent it?
Old Sep 26, 2001 | 06:36 PM
WykidEH's Avatar
Default Re: Hood Venting for a turbo (revhrdls)
yes it would. a friend did his and it dropped the under hood temp. way down
Old Sep 26, 2001 | 08:08 PM
PureTeg420's Avatar
I've seen a CF hood for USDM integras that had the mugen style vent on it. It looked pretty damn sweet only I wish I knew who made it.
Old Sep 26, 2001 | 08:14 PM
redline's Avatar
Default Re: Hood Venting for a turbo (PureTeg420)
check out importparts.com
Old Sep 26, 2001 | 09:23 PM
quikrpm'z's Avatar
is there any that prevents the water from getting inside?
[Modified by quikrpm1, 10:24 PM 9/26/2001]
Old Sep 26, 2001 | 09:38 PM
integRated109's Avatar
Default Re: Hood Venting for a turbo (redline)
i ordered one of the imoto vented hoods from importparts. soon as it gets here ill post pics. ...BTW.....hey ben, any word on the hoods yet?
Old Sep 27, 2001 | 09:04 AM
IgniteTeg's Avatar
Default Re: Hood Venting for a turbo (integRated109)
Will water affect the turbo or whatever gets in?? My vented CF hood is located right at the exhaust manifold. So will the turbo gets affected if water or rain gets in?? Or anything else gets mess up?? Or its safe? How about a machine car wash will anything gets damage with this vent??? Or I will be okay. I heard this from somebody that says if the exhaust manifold (header) or turbo manifold gets too hot and water touches it it tends to crack. Is this true??????? Btw, can i still use my factory rubber thingy that goes around the factory hood to be put on my cf hood? How do I take it off it seems to be glued very tightly or screwed down tightly. I really need imputs badly regardin my CF vented hood at the exhaust manifold thanks for all the great help.
[Modified by IgniteTeg, 10:05 AM 9/27/2001]
Old Sep 27, 2001 | 09:35 AM
Default Re: Hood Venting for a turbo (IgniteTeg)
i bought one of those reactive filters with the plastic heat shield to keep water out of that. im not sure about the manifold, of course its not good to pour water on something that hot, but if it only comes in drops it shouldnt hurt anything. ill probably end up fabricating a heat shield for my mani. and turbo just to be safe.
Old Sep 27, 2001 | 10:32 AM
falcongsr's Avatar
What is this crap?
yeah you had better make a heat shield of some sort. anything more than a few drops of water and you can bet on the manifold cracking.
Old Sep 27, 2001 | 01:49 PM
quikrpm'z's Avatar
Default Re: Hood Venting for a turbo (falconGSR)
not to mention heavy rusting.
Old Sep 28, 2001 | 02:10 AM
IgniteTeg's Avatar
Default Re: Hood Venting for a turbo (quikrpm1)
damn this sucks just got the vented cf hood too Where can i get a custom heat shield exhaust mani?? Btw I'm sure with this I would have no room for the turbo this just suck!! I knew I shoulda just got the regular one. Thanks for all the help peepz. Will I be safe if its rainin???? Or even a machine car wash???? These 2 are my main concern please help once more.
Old Sep 28, 2001 | 06:13 AM
what hood did you get? if you are really worried you could use tape or something to block the vent temporarily until you can make a heat/rain shield.
Old Sep 29, 2001 | 03:33 AM
IgniteTeg's Avatar
I got it from my local racing shop. Do you think its still safe???? This really sucks
Old Sep 29, 2001 | 04:16 PM
Blownlude's Avatar
New User
You definitely don't want water touching your turbo when it is hot. Even though you can't see it, turbos get red hot sometimes. Get a bunch of water spraying on it and you WILL damage it. I would try to direct the airflow away from your exhaust manifold.
Old Sep 29, 2001 | 08:16 PM
PureTeg420's Avatar
Default Re: Hood Venting for a turbo (Blownlude)
unless your getting the greddy kit, I'd think it would be tough to made a heatshield because the wastegate sticks so far up to the hood.
Old Sep 30, 2001 | 10:42 AM
i just started on my heat shield. its thin sheet metal, hooks to the two bolts sticking up on the exhaust side of the valve cover, and has a hole cut for the tial and dipstick. ill make improvements on the design as i go, but it should work pretty good.
Old Sep 30, 2001 | 11:38 AM
turbopanda's Avatar
this was one of the main reasons why I had my external wastegate hanging down below, instead of on the top..
this is my current setup with the heatshield.. really to protect the hood from melting
this is my old setup. the turbo is down below on this one, as well as my HKS external wastegate, not only does this stop the rain, but I find it helps to cool things down as the wind coming from the fans on my radiator are forced to hang around that area, which keeps things cooler.
of course, if you guys want vents in your hood, why don't you just do what I did? its cheap (not even a dollar) and effective: raise the rear of the hood by adding washers and a bolt or two into the hinges that hold the hood to the body of the car.. works well, just don't forget to take off the heatshield from the underneath of your hood (if you have one)..
Old Sep 30, 2001 | 12:50 PM
JM Performance's Avatar
Default Re: Hood Venting for a turbo (nathan's boosted civic)
wow, that looks good (the hood trick). does it work?
Old Sep 30, 2001 | 10:07 PM
IgniteTeg's Avatar
Default Re: Hood Venting for a turbo (00SilverLS)
Does anybody know if my vented cf hood safe its vented above the manifold. I would hate to get rid of it. I just bought it 3 days ago too. Hate to blow a lot of money on something thats not safe. This really sucks.... Would I be able to bring it to a machine car wash and be safe?????? Or the manifold will crack and stuff?? How about on rainy days???? If its parked??? or driven???? I would deeply appreciate everyone feedback on this please Also any other ways to still keep my vented cf hood???? What will happen if manifold cracks????Thanks.
Old Oct 1, 2001 | 03:02 PM
Jon7's Avatar
I looked into the imoto hoods a while back. Why don't you go log onto jegs.com and order some foam hood scoop plugs. They aren't expensive. When you get them in, just cut it accordingly to the vent sizes in the hood. Use them when it looks like rain and always have them in the car in case it does. On sunny days, just take them out and enjoy the benefits of the vents in the hood. I wouldn't take a nice car of mine to a car wash anyway...wash it by hand.
Old Oct 1, 2001 | 03:04 PM
BoostinDC2's Avatar
Default Re: Hood Venting for a turbo (Jon7)
i hear the washers trick works well
Old Oct 1, 2001 | 08:16 PM
IgniteTeg's Avatar
Cool Jon7 thanks for your help. Any pix of this foam hood scoop plugs used before?
BoostinDC washer? How can washer help and where does it goes?? Any pix of it? Thanks guyz.
Old Oct 2, 2001 | 02:05 PM
IgniteTeg's Avatar
I have a question and an idea. Is there a way I can custom something to take in and out to cover the hood vent. Like when its rainin I put back the thing to cover the vent and when its very hot or its not rainin i remove taht thing. Just like a clip on and off thingy???? Anyone know how or any ideas??? Thanks really would I be fine???? What happen if a manifold crack?? And your drivin also??
Old Oct 2, 2001 | 07:02 PM
Zeus's Avatar
...for christ's sake! go to the local hardware store and spend $20 or less on some sheet aluminum and a pop rivet gun/ 1/8" pop rivets... on the way home, stop by the auto parts store for some aluminum polish(so you can make it pretty when your done) for a few more bucks. Make your custom heat shield simple as to keep water from pouring on the turbo and mainfold, but not as to block too much air flow... a desent example is provided above... the top picture is uglier, but more of what you want it to function like...
[Modified by Zeus, 8:05 PM 10/2/2001]
miff
Apr 1, 2004 09:06 AM
scooter
Jul 16, 2003 03:46 PM
Boostless97Lude
Sep 7, 2002 09:04 AM
daebyuck
Feb 21, 2002 09:17 AM
IgniteTeg
Oct 4, 2001 09:40 AM
