hondata shift light and idle...need help.
Old Jan 17, 2003 | 09:23 PM
Lei Siew Long's Avatar
Default hondata shift light and idle...need help.
recently had some idle problems so, when the idle would fluctuate from 1100-1300 rpm when warming up the shift light would be on at 1300 and as soon as it dips to 1100, it would turn off.
this is also the case when cruising. when i'm at partial throttle increasing speeds, the shift light flickers on and off and when i let off and drop it into neutral so it would idle, it comes back on.
is there a wiring problem or is the unstable and fluctuatiing idle causing this?
[Modified by boostedeg6, 11:33 PM 1/17/2003]
Old Jan 17, 2003 | 11:54 PM
Rocket's Avatar
Default Re: hondata shift light and idle...need help. (boostedeg6)
Are you running a P28 ECU? The Hondata program for the P28 had a glictch. Contact me if you need further help.
Old Jan 18, 2003 | 01:29 AM
Default Re: hondata shift light and idle...need help. (Rocket)
i'm running the p74 ecu. it didn't have this problem before until i started having idle problems.
00siandrew
Jun 19, 2006 01:15 PM
vtecmike1
18
Feb 13, 2005 01:57 PM
JM Performance
Jun 18, 2003 04:01 PM
MeanGreenEG9
Apr 8, 2003 07:06 AM
