hondata s300 base map ?
ok i have a b18c5 with my turbo kit in the mail (turbonetics). i was messing around with my s300 and seen that there is a base map for a B18c5 with a revhard turbo kit.
I am wondering if i can drive my car on this map to a shop to get it tuned and would it be safe. I was also wondering if any body knows a good shop in germany. thank you for your time.
set up
B18c5
hondata s300
650cc prescion injectors.
turbonetics turbo kit
t3/t4 turbo
set up
B18c5
hondata s300
t3/t4 turbo
More than likely. It's based upon the turbocharger used, in which case it is more than likely a 57 or 60 trim. If your intent is strictly to drive it to the tuner so the computer can be refined, then it shouldn't be a problem.
also make sure that the injectors are scaled properly. also make sure your injector scaler and map sensor settings are correct. i think the basemap uses 550s and oem map, so make sur to match it to your setup before firing the car
and of course...do no boost on the basemap
x2, I just looked in my s300 files the revhardb18c5 is for an sc61...It has the fuel setup to be 440cc injectors you will have to change that, and it is running a stock map sensor, that needs to be changes as well...Stay out of boost you will be fine.
