hondata s200/s300?
Old Oct 23, 2006 | 07:21 AM
EJ8 GSR-T's Avatar
Default hondata s200/s300?
Can someone explain the difference to me?
Old Oct 23, 2006 | 09:05 AM
EJ8 GSR-T's Avatar
Default Re: hondata s200/s300? (EJ8 GSR-T)
right now i have a chipped p28 with hondata s200; the prob is my shop dosnt have the softwear nor do they have a chip burner....so im thinking maybe i can upgrade to hondata s300 becuase all you need is well a laptop w/ usb? am i right? What kind of ecu/ecu modification would i need?
Old Oct 23, 2006 | 11:23 AM
B.'s Avatar
B.
400 HP Club
one had boost option built in (s300) and the s200 does not.. And the s300 is more tuner friendly.. And yes the s300 had a usb plug adapted to your p28..
Old Oct 23, 2006 | 11:43 AM
ATYPR's Avatar
Default Re: hondata s200/s300? (B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B. &raquo;</TD></TR><TR><TD CLASS="quote">one had boost option built in (s300) and the s200 does not.. And the s300 is more tuner friendly.. And yes the s300 had a usb plug adapted to your p28.. </TD></TR></TABLE>
WTF!
http://www.hondata.com/s300.html
Old Oct 23, 2006 | 12:23 PM
EJ8 GSR-T's Avatar
Default Re: hondata s200/s300? (FUCATYPR)
well the hondata page is a bit misleading uptop it say "utilizes facotry ECU" then down it sayd "ECU must be modified". My question really is what will i have to do wtih my ECU to change it form using the s200 system and make it use the s300 system? Also if i am running s300 does my tuner need to have a chip burner at all??? And whatever that bs was about boost...the s200 has it also...so please peeps give me some realiable info to go on.thanks
Old Oct 23, 2006 | 02:04 PM
WalkerGSR1's Avatar
When they say utilizies facory ecu they mean that its not a seperate ecu like the aem ems.
Old Oct 28, 2006 | 11:29 PM
Cole D's Avatar
read the post below much better explanation
Modified by Cole D at 11:24 PM 10/29/2006
Old Oct 29, 2006 | 05:30 AM
IN VTEC's Avatar
The s300 is a daughterboard with real-time programming built into it. The S200 is a blue box that sits external to the ECU casing and connects to the ECU through a 4-pin wire (see pictures of S200 on website). Because the S300 already has real-time programming and datalogging built into the daughterboard, you don't need to have a ROMulator or a chip burner. The S200 does require a chip burner and ROMulator (or either of the two).
Boost is an option on the S200, but it's a standard feature on the S300...FTL/FTS are also standard on the S300 and optional on the S200.
The S300's SManager software can also do a lot more than the S200's ROMeditor software....detailed IAT/ECT/gear correction, boost control/cut, wideband offset, on-board datalogging, anti-lag, Alpha-N crossed with speed-density, etc. etc. etc.
Both use factory ECU's. Both require the ECU to be modified so that it can datalog and read from external memory (it's called socketing).
If you don't already have a S200, buying a S300 is practically a no-brainer.
Old Oct 29, 2006 | 08:46 AM
DRIVENRacing's Avatar
s300 rocks it...
AzN_Flava
Engine Management and Tuning
Sep 15, 2017 10:33 PM
spoonhatchblack
Dec 12, 2008 11:28 PM
H22Luda720
Mar 31, 2006 09:51 AM
