hondata question
Old Dec 4, 2002 | 02:18 PM
itr449's Avatar
Default hondata question
i'm going turbo on my itr soon and i'm installing the kit myself but not the hondata. should i get the hondata installed first and then the turbo or turbo first then hondata? sorry if this is stupid question, but i just had to ask.
Old Dec 4, 2002 | 02:27 PM
ekb18c's Avatar
Default Re: hondata question (itr449)
Install the turbo kit yourself, then drive the car (Very carefully) to the nearest Hondata dealer for tuning and install of hondata.
[Modified by ekb18c, 11:27 PM 12/4/2002]
Old Dec 5, 2002 | 06:53 PM
333's Avatar
333
Default Re: hondata question (ekb18c)
you are supposed to install Hondata, then see if the car start and runs good because it uses the non boost tables. Drive it around, if you have stage 4 tune the non boost or off boost area first then tune boost later, like after in stall. possiblity of running lean if install turbo then hondata depending on your set up. But When I got my hondata I didn't read and installed the turbo first then Hondata. blow my motor, now on a rebuilt motor it was a pain in the **** to tune boost and off boost fuel and ignition tables. Remember read Hondata carefully. Greatfull Hondata owner in CT.
Old Dec 5, 2002 | 06:59 PM
itr449's Avatar
Default Re: hondata question (321)
thanks for the info
Old Dec 5, 2002 | 07:00 PM
ekb18c's Avatar
No, you can NOT install hondata first because you will need a program in there. The chips come blank. You can drive your car over to the nearest hondata dealer for tuning with your stock computer. Besides if you didnt get your computer chipped yet, you will not be able to connect the interface box to the ecu.
HTH
Old Dec 5, 2002 | 07:12 PM
sutrusu's Avatar
all the places i know of that sell hondata put a base map on it so you can drive it to the tuner... carefully. very very very carefully.
[Modified by sutrusu, 4:13 AM 12/6/2002]
Prudz_lude
May 29, 2007 07:01 AM
chewiejdh
Mar 16, 2004 02:29 PM
i3oricua
Jul 5, 2003 10:23 PM
Dorikamu
May 2, 2002 10:31 AM
