hondata question
Old Feb 11, 2007 | 07:08 PM
Turbo_y8's Avatar
Default hondata question
i have a question regarding hondata. currently im running a obdI ecu with crome. Ive been eyeing up hondata but am wondering what i would need to switch over and run it. ecu's are not my area. what would be the better buy s100 or 200.
Thank you
Old Feb 11, 2007 | 07:17 PM
93turbo16's Avatar
Default Re: hondata question (Turbo_y8)
Honestly, the only one I would go with over crome would be the S300.
But to answer the question, they should be setup exactly the same for either system. You might have to add/remove jumpers at J12 to get it to work. Your tuner or install instructions for the S100 or S200 will point you in the right direction.
Old Feb 11, 2007 | 08:15 PM
Turbo-LS's Avatar
S300 FTW, you need to have the socket desoldered from the boared and have the S300 pins installed in the socket area and also the 4 pin for datalogging installed. Also need to remove or cut j12 jumper. cut the ECU housing on the side for the usb connection and your ready to rock n roll
I highly recomend a professional does the work. its easy to screw it up and youve already stated you dont know much about ecu's
Old Feb 11, 2007 | 11:24 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_y8 &raquo;</TD></TR><TR><TD CLASS="quote">i have a question regarding hondata. currently im running a obdI ecu with crome. Ive been eyeing up hondata but am wondering what i would need to switch over and run it. ecu's are not my area. what would be the better buy s100 or 200.
Thank you</TD></TR></TABLE>
Do some research for your self.
Read hondata.com
http://www.tunewithcrome.com
Another option for you is neptune rtp.
They all have a common goal, some systems have better features then others for specific applications etc.
prelude2.2
Mar 5, 2013 09:17 PM
Nicks95GSR
Dec 3, 2008 04:48 PM
legendboy
Dec 18, 2002 03:59 PM
EVOTHIS
May 18, 2002 08:11 AM
