hondata probs. please help.
Old Jun 8, 2002 | 05:41 AM
turboex's Avatar
Default hondata probs. please help.
Ok i have totally installed the hondata 3b on my 2000civic si using a p28 ecu and the car started fine. however i can not retreive the codes from my ecu, the check engine light comes on for about 2 secs then goes out for a quick sec and then stays on. Any ideas on whats going on here? how can i quickly fix this?
Old Jun 8, 2002 | 12:30 PM
turboex's Avatar
Default Re: hondata probs. please help. (turboex)
come on guys. wheres gruytrain when ya need him. i need help super fast. could i just have a bad rom or is my ecu bad? please help
Old Jun 8, 2002 | 02:35 PM
turboex's Avatar
man, 50 views and no responces. please guys!
Old Jun 8, 2002 | 02:43 PM
Arturbo's Avatar
Better than steak
25 Year Member
is the light on your interface box flashing?
Old Jun 8, 2002 | 03:11 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: hondata probs. please help. (Arturbo)
come on man, after 60 views and you still havent responded to me. Hurry up my time is limited.
art
Old Jun 8, 2002 | 03:18 PM
DA666's Avatar
its actually gruvytune
not gruyttrain
but good luck diagnosing anyway.
Old Jun 8, 2002 | 03:27 PM
turboex's Avatar
Default Re: hondata probs. please help. (T3T4DA6)
Sorry arturbo. thanks man i was out side trying ****. ok..... with the rom in the light on the hondatabox is solid red. and the check engine light is on all the time and shows no codes. so i pulled the rom and the red light started to blink on the hondatabox. then i even tried to cut the jumper to return my ecu to stock and it ran the car fine with no check engine lights. so the ecu must be good. and if the light on the box blinks when i pull the chip then it sounds like its all hooked up right. thanks for comenting art. i m thinking the chip is bad or not burned. if you put a new chip with no program on it then what will the car do? i dont have one but would it do as my car is doing? thanks again
[Modified by turboex, 12:31 AM 6/9/2002]
Old Jun 8, 2002 | 03:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
if you put in a chip in there with no program it will do just what you described. It is running off the back up processor and the CEL will stay one. I had the same problem because I thought I had burned the chip but I hadnt. I burnt it and it started right up. Hope that helps...
art
Old Jun 8, 2002 | 03:38 PM
turboex's Avatar
thanks man, well i got mine in the huge c-speed group buy. so im guessing that they just missed mine. i hope. thanks again
Old Jun 10, 2002 | 12:18 PM
turboex's Avatar
well im still working on it. im gonna try the hondata reset. and then talk to c-speed tonight and see what we can figure out. any more ideas?
Old Jun 10, 2002 | 12:20 PM
sgT's Avatar
sgT
if the hondata light is on constant then the rom should be good.
check the error code the old fashioned way by jumping the service connector.
Old Jun 10, 2002 | 12:36 PM
SIK IN DA HED's Avatar
New User
Default Re: hondata probs. please help. (sgT)
hey sgT, do you really have that many posts? DAYAM.
Old Jun 10, 2002 | 12:45 PM
sgT's Avatar
sgT
Default Re: hondata probs. please help. (dlplayboy)
Leftovers from the other night's madness
Old Jun 10, 2002 | 01:46 PM
turboex's Avatar
i tried to check the codes witha jumper wire, and all that but its no good. it will not let me view the codes. the check engine light just stays on. any ideas? thanks for the great help so far. all these views and finally some good answers. thanks guys
Old Jun 10, 2002 | 02:42 PM
GruvyTune's Avatar
New User
dude, are you there? you home? can you call me? i'll try and help ya.
As Art said, if you get a solid light on the hondata then the ROM chip really must be good. If you cut your jumper and you can start your car without a CEL then your ecu is probably good. If you get a check engine light with the hondata ROM but your hondata box is solid then you probably have a poorly soldered modification to your ecu!
torin
[Modified by GruvyTune, 6:46 PM 6/10/2002]
Old Jun 10, 2002 | 03:00 PM
turboex's Avatar
Default Re: hondata probs. please help. (GruvyTune)
hum. that maybe true. how can i check this? hey man if you can IM me ill call ya asap. any help is apriciated. thanks
you can reach me at
ICQ 44583735
AIM damianhindley
thanks again
[Modified by turboex, 12:24 AM 6/11/2002]
Old Jun 10, 2002 | 06:49 PM
turboex's Avatar
ok heres the deal so far its not good yet. but were getting there i hope as of now i have cspeed sending another romchip so i can give it a try. ok i read the a post on clubsi about using a scantool to check why my enging light is on (which i will get from work tomorrow to check out why my car is giving me a check engine light "mil" as it will not produce any codes when the plug is tested/jumped) so I wanted to see if i just had a real bad base map. so i started the car out side of the garage. once again the check engine light is on and thing exhaust is putting out more smoke then a tug boat. and its alll fuel. i all heard the bov as i pulled the car out of the garage. this is totally crazy to me but when i rev the car to 3000rpm or higher i can hear the bov clear as day and this is with the car sitting still. no load. It has never done this before. I also noticed that my boost gauge is reading at neg3 and not at neg18to-21. i actually made 3psi of boost just punching the gas as the car idled. so somthing is really wrong here. were guessing the chip. i also cut the car of and then pulled the jump to return the ecu to stock and then started the car. it idled a little rough because of the dsm injectors but not hardly any smoke and the vac was back to normal and there was no bov when i punched the gas. any ideas guys? this is a great learning experance for me. so i need all the help i can get here. If the chip is infact good and the ecu is good. then what could be left that is causing the car to run in limp mode? I do have a obd2 to obd1 harness but if it was bad in any way in sure it would throw a code when the jumper was cut and the ecu was stock right? thanks for the help keep it coming. im gonna give the scantool thing a try tomorrow. any other ideas?
heres the link to clubsi if you would like to compare info with otehr hondata guys and help me out. thanks so much!!
http://forums.clubsi.com/showflat.ph...c=1&PHPSESSID=
Old Jun 10, 2002 | 07:02 PM
GruvyTune's Avatar
New User
first off, if the harness were bad, you would probably not be able to start your car with the ecu set to stock without a CEL coming on. So, as I had told you, that part is ok. With the hondata unit, if the ROM is ok and without errors, the hondata light will stay solid (as your's does). The problem herein lies with the ROM code on your chip in that your ecu does not read it as a valid set of maps (or some other set of bad code). This error happens when the chip is burned for the wrong ecu type! Fortunately, you will probably be ok once someone burns you a chip appropriate for your ecu. If the new chip they burn is not working I suggest you send the entire setup to someone who can test it as a unit in another car!
torin
Old Jun 11, 2002 | 03:01 AM
turboex's Avatar
thanks alot man. thats some good help. thats what ill be doing. ill keep everyone updated. thanks again
Chris Thompson
Engine Management and Tuning
Apr 29, 2019 02:57 PM
94GSRMR
Sep 29, 2010 12:06 PM
HatchWithBlades
Apr 17, 2007 01:28 PM
crxvtecturbo
Jul 14, 2005 07:48 PM
busakiller
Aug 14, 2004 07:33 AM
