I was wondering if a GM 3 BAR MAP sensor will work with a Hondata? or would you have to use the 3 bar that Hondata sells?
GM 3 bar map sensor works fine. You just have to splice in the respected GM style clip into the wiring harness.
http://www.hondata.com/3barinstall.html
The 3 bar that Hondata sells is a GM map sensor.
[Modified by TheShocker, 6:34 PM 12/14/2002]
