Hondata and Keyspan USB to Serial adapters
Old Jul 13, 2004 | 11:25 PM
PrecisionH23a's Avatar
Default Hondata and Keyspan USB to Serial adapters
The old keyspan USB to PDA
http://www.keyspan.com/products/usb/pdaadapter/
has been replaced by this one
http://www.keyspan.com/products/usb/usa19w/
Are any of you using the newer model one and do they work in conjuction with hondata and what not?
Old Jul 13, 2004 | 11:30 PM
Stewie's Avatar
Default Re: Hondata and Keyspan USB to Serial adapters (PrecisionH23a)
this was covered already not too long ago. I suggest you do a search because some good links to the hondata forum were provided.
Old Jul 13, 2004 | 11:33 PM
Default Re: Hondata and Keyspan USB to Serial adapters (Stewie)
Thank you for pointing out the obvious stewie.
Neither site has dealt with the keyspan usb 'upgrade' as it is fairly new to my knowlege.
Old Jul 14, 2004 | 05:32 AM
Doodoo's Avatar
I have had the smoke housing one for about a year. When my car did run the adapter worked fine. It connected much better than the serial, MUCH better. I had constant drops while datalogging by serial. I found mine at CompUSSR.
Modified by Doodoo at 11:17 AM 7/14/2004
Old Jul 14, 2004 | 08:01 AM
TheShodan's Avatar
Moderator
This dilemna has always been present I've noticed when it came to the datalogging using Serial vs, the adapter. ON the actual tuning of the tables the adapter mainly works, w/ an occasional blue screen of death, but for datalogging, I've found that it still constantly drops off.. strange
Old Jul 14, 2004 | 02:38 PM
b18cls1's Avatar
Default Re: (TheShodan)
ive used both and no major problems with either on but i mainly use a socket pc card adapter and its rocksolid..as much as a pc can be...
Old Jul 14, 2004 | 03:32 PM
Default Re: (b18cls1)
I've looked into the serial i/o port, damn $180 bucks! I went ahead and ordered the 2 keyspans, it better ******* work.
Old Jul 14, 2004 | 04:24 PM
b18cls1's Avatar
Default Re: (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">I've looked into the serial i/o port, damn $180 bucks! I went ahead and ordered the 2 keyspans, it better ******* work.</TD></TR></TABLE>
both of mine work fine you shold be fine.
b16a27
Oct 17, 2004 11:22 PM
phreekyshpoon
Jul 8, 2004 05:19 AM
ramz7887
Apr 10, 2003 02:04 PM
Spunkster
Feb 11, 2003 11:19 AM
BLaCKWiDoWSi
Nov 2, 2001 08:14 AM
