Hondata harness need help broke plug....
Old Mar 15, 2006 | 11:04 AM
spoolingb20's Avatar
Default Hondata harness need help broke plug....
It is the 4 wire harness that goes from the ecu to the s200 blue box. The black end all four wires pulled out on me. What I need to know is the order that they were in there so i can try and repiar this. If I cant get the pins out of the black clip, then I cant rewire it. (The black clip is the end of the harness that plugs into the blue box from the ecu) Is there some place that sells replacement harness? Is there some way for me to pull the pins out casue I cant get them? Last I need the order the wires go back into the black plug?
Thanks
Steve
Old Mar 15, 2006 | 12:26 PM
Default Re: Hondata harness need help broke plug.... (spoolingb20)
Q
Old Mar 15, 2006 | 12:44 PM
turbo*s2k's Avatar
Your best bet would be to call Hondata.
Old Mar 15, 2006 | 03:35 PM
Default Re: Hondata harness need help broke plug.... (TurboChrgd_Civic)
i c u have the same unit I have for sale would you be able to just look at the black plug and give me the order the wires are in it. The wire colors are orange red brown black...
Thnks
Old Mar 16, 2006 | 09:10 AM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolingb20 &raquo;</TD></TR><TR><TD CLASS="quote">i c u have the same unit I have for sale would you be able to just look at the black plug and give me the order the wires are in it. The wire colors are orange red brown black...
Thnks</TD></TR></TABLE>
with the harness plugged in and hondata box upright.
it's red, and black on top from left to right.
orange, brown on the bottom left to right.
Does that make sense??? Hope that helps, good luck...
Old Mar 17, 2006 | 01:07 PM
thanks so much worke dout perfect / I was able to get pins from radio shack and just hard wired it into the blue box.
Thanks Again....
Hondata got back with me and let me know some of there retailers in the area that had that harness in stock and they all wanted $40 dollars...
jrsh0526
10
Jan 21, 2014 08:16 AM
philkehn
Jun 13, 2006 08:46 PM
WickedWerx
Nov 1, 2004 08:18 PM
dingusjt
Nov 22, 2003 07:24 PM
