hondata gurus
Old Sep 29, 2003 | 10:54 AM
GreddySi99's Avatar
Default hondata gurus
Do you know if the rev limiter and stage limiter cuts fuel or boost???? thank you
Old Sep 29, 2003 | 11:05 AM
boosted hybrid's Avatar
Default Re: hondata gurus (intercooledJRSC)
Fuel.
Old Sep 29, 2003 | 11:29 AM
ladysman's Avatar
Default Re: hondata gurus (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">Fuel.</TD></TR></TABLE>
Yep Fuel.
Old Sep 29, 2003 | 11:37 AM
GreddySi99's Avatar
Default Re: hondata gurus (ladysman)
Isnt that a bad thing??? I thought when you cut fuel per say hitting the rev limiter that you would creat a lean situation and cause detionation and blow the engine. is this true? I also had thought that that is why puting a ingnition type of rev limiter was a better way to solve the problem. please enlighten me on this situation
Old Sep 29, 2003 | 12:54 PM
GreddySi99's Avatar
anyone have any input on this???
Old Sep 29, 2003 | 02:37 PM
5thgencivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intercooledJRSC &raquo;</TD></TR><TR><TD CLASS="quote">Isnt that a bad thing??? I thought when you cut fuel per say hitting the rev limiter that you would creat a lean situation and cause detionation and blow the engine. is this true? I also had thought that that is why puting a ingnition type of rev limiter was a better way to solve the problem. please enlighten me on this situation</TD></TR></TABLE>
That's what I always thought as well.. Anybody have any insight?
Old Sep 29, 2003 | 03:12 PM
ladysman's Avatar
All I can say is I hit the rev limit all the time and my stock block hasn't blown yet.
I see your concern but with no fuel, the engine literally shuts off then back on again quickly.
Hondata could provide a more technical answer.
Old Sep 29, 2003 | 03:17 PM
Marauder's Avatar
I thought it cut cylinders off.....ignition wise.
Old Sep 29, 2003 | 03:35 PM
ski_rebel_3's Avatar
Default Re: hondata gurus (Marauder)
Here's my thinking...
If it cut ALL fuel then there would be nothing for the spark to ignite. If there is no explosion of fuel then there couldn't be much damage caused.
That's my guess anyway.
Old Sep 29, 2003 | 03:40 PM
Andrea's Avatar
Default Re: hondata gurus (ski_rebel_3)
Compressed air with small particle content of gasoline can easily ignite and/or detonate. When the engine is moving dynamically, air is being pulled through the combustion chamber very quickly. The particle content of the fuel cut would be so small since exhaust scavenging is taking place, detonation would not occur.
Old Sep 30, 2003 | 11:49 AM
GreddySi99's Avatar
Default Re: hondata gurus (50trim EK)
well does anyone know for sure ??????
Old Sep 30, 2003 | 12:01 PM
Nothing will happen when you hit either the rev limiter, or boost cut. I have hit both many times before with my personal car, as well as customers cars. No damage has ever occured. 50trim EK's explanation is correct.
Old Sep 30, 2003 | 12:04 PM
IloveNewt's Avatar
If you guys wanna be sure, get an MSD ingition box. I have the hondata fuel cutoff and also the MSD Spark cut off at 7200rpm.
geeman640
Honda Civic (2006 - 2015)
13
Oct 5, 2007 12:00 PM
civic gtr
Nov 13, 2004 09:50 AM
Nick7
Feb 25, 2004 03:08 AM
westsidejdmyo
12
Dec 30, 2003 04:09 AM
TypeR 01 886
Jul 30, 2003 03:10 AM
