Hondata or AEM EMS ??????
Old Jan 7, 2003 | 06:24 PM
bottlefedb18c1's Avatar
Default Hondata or AEM EMS ??????
what do you think is better for tunning reasons and for reliability?
and ease to use, it is a tossup between the s200 with boost option ect. ect. ect. (with all the options like the 4b) or the AEM EMS
Old Jan 7, 2003 | 06:30 PM
sharkcohen's Avatar
Default Re: Hondata or AEM EMS ?????? (boostfedb18)
Get whatever your tuner is experienced with using.
Old Jan 7, 2003 | 06:32 PM
Default Re: Hondata or AEM EMS ?????? (sharkcohen)
i stuck for hondata unless some knows anyone in New york 1 hour south of albany and about 1 hour north of nyc. I am kinda stuck in between a rock and a hard spot for hondata unless someone knows someone???
Old Jan 7, 2003 | 07:39 PM
MotorMatrix.com's Avatar
I am a bad person
Hondata very easy to use and tuning can be done with less dyno pulls than an AEM.
Old Jan 7, 2003 | 07:53 PM
Default Re: Hondata or AEM EMS ?????? (MotorMatrix.com)
Does the AEM have the auto tune opption and if so does it work good?
Does Hondata have something like that? I like the Hondata better myself i am just tring to get my mind straight with what i can do.
Old Jan 7, 2003 | 08:49 PM
DD_JonnyLee's Avatar
what he said
Old Jan 7, 2003 | 09:01 PM
Default Re: Hondata or AEM EMS ?????? (JonathanH)
the only real one is wants to run a accel DFI in my car but i am going to drive it every day
Old Jan 7, 2003 | 09:13 PM
MachAF's Avatar
How can hondata be tuned in less dyno pulls?
AEM can be tuned with zero dyno pulls, wideband = autotune.
Anyway. AEM is more user friendly, easy to change settings. With hondata you gotta burn a new rom.
AEM is very complex, learning the program takes time.
If your going to do the tuning yourself and change it a lot go with AEM.
If someone else is going tune go with Hondata. If their no hondata tuner close to you, then AEM.
Old Jan 7, 2003 | 09:22 PM
Default Re: Hondata or AEM EMS ?????? (machaf)
There is no Hondata tunners around here that i know about.
That is what i really wanted to know how it really works, but i do like the s200
Thanks
Old Jan 7, 2003 | 09:27 PM
sharkcohen's Avatar
If you go with AEM, spend the extra money and get a wideband setup for it.
Old Jan 7, 2003 | 09:32 PM
Tinker219's Avatar
Whats the cost of the cheapest/most effective wideband setup? Im in the same boat, except I am a good 5 hours from ANYONE who would know what standalone even is, let alone a dyno...
Old Jan 7, 2003 | 09:38 PM
MachAF's Avatar
Default Re: Hondata or AEM EMS ?????? (Tinker219)
People on here have had great things to say about the techedge unit, I believe they were using the NKG wideband unit, not sure though.
Here is a link to it:
http://www.techedge.com.au/vehicle/wbo2/default.htm
Old Jan 7, 2003 | 10:27 PM
LS-hatch's Avatar
how much is the aem system going for now anyway?
Old Jan 7, 2003 | 10:29 PM
i will check it out
thanks
Old Jan 8, 2003 | 06:39 AM
Tinker219's Avatar
I like that....if I remember correctly, widebands were going for as much as $800. Thanx for the info....
Old Jan 8, 2003 | 06:52 AM
prophet's Avatar
800 is way off...i got my techedge for 265 i think and got the sensor for 100 shipped....so for less than 400 bucks you can have yourself something that will definately aid you in tuning wether its a hondata OR a AEM.
Old Jan 8, 2003 | 08:14 AM
Tinker219's Avatar
Default Re: Hondata or AEM EMS ?????? (prophet)
Did you get the pre-built kit, or the DIY kit? Ive never really fucked with electronics on this scale before....
Old Jan 8, 2003 | 08:19 AM
Slick GS-R's Avatar
bump
Old Jan 8, 2003 | 11:18 AM
prophet's Avatar
prebuilt kit...i wouldn't spend more than $500 on the techedge plus sensor anyways since you can get a good FJO one for around $600...you don't need those neat display units (although with the prebuilt you get it) since it should be logged anyways.
toofresh1993
Engine Management and Tuning
13
Mar 13, 2010 06:51 AM
sloboy_joe
32
Nov 15, 2004 03:43 PM
sohcvtec66
36
Dec 8, 2003 09:30 PM
BoostedsiR
Apr 20, 2003 07:43 PM
Feb 22, 2002 07:24 AM
