hondata
Old Jan 30, 2003 | 07:10 PM
dalepatters's Avatar
Default hondata
I have a 1990 teg with a turbo setup,can I run a hondata and what would I need to do this since my car is obdo
Old Jan 30, 2003 | 07:11 PM
ekb18c's Avatar
Default Re: hondata (dalepatters)
You need a pr3 or a pw0 ecu to run Hondata.
Old Jan 30, 2003 | 07:27 PM
Default Re: hondata (ekb18c)
I will give you guys a call tomorrow because I was told by the hondata tuner in Atlanta that all I had to do is bring my ecu which is a pr4 and they would install hondata an give me a base map and I can go get it tuned
Old Jan 30, 2003 | 07:30 PM
ekb18c's Avatar
Crap I'm wrong..
Here I'm thinking you have a vtec motor in the integra.
pr4 will work only if that pr4 is obd1 ecu.
Old Jan 30, 2003 | 07:36 PM
My pr4 is obdo what would I need for a obd1 to work in my car also can i run it with stock injectors or I need to upgrade
Old Jan 30, 2003 | 09:09 PM
Spunkster's Avatar
convert to an obd1 distributor and coil and get a obd0 to 0bd1 adapter harness.
Old Feb 13, 2003 | 09:53 AM
bretx0r's Avatar
Default Re: hondata (Spunkster)
u might wanna try zdyne instead. there are plenty of obd0 standalone systems
Old Feb 14, 2003 | 02:48 PM
WONG FRIED RICE's Avatar
yes...u would need to convert the distributor, get an OBD1 ECU, you could run with stock injectors... i think it would be more to your liking if you got a little bigger ones.
93delslow315
May 27, 2010 09:23 PM
R6E6I6D
Jul 24, 2005 06:08 AM
quik1
May 12, 2004 07:35 AM
SiRex91
May 8, 2003 07:10 AM
C4wrx
Aug 9, 2002 12:00 AM
