Hondata 2B has blinking red led?
Old Apr 5, 2005 | 11:41 AM
uHz ! B18C1's Avatar
Default Hondata 2B has blinking red led?
when i plug it up, the red led is blinking....is it broken?
cant seem to get a reading from it
Old Apr 5, 2005 | 12:00 PM
Finest's Avatar
Default Re: Hondata 2B has blinking red led? (uHz ! B18C1)
Check that the chip is sitting properly inside the socket. Also check the two wire connector from the blue box to the ecu.
Also, this one time I didn't burn the chip correctly and basically put in a blank chip. Took me forever to figure it out since I "thought" the chip was properly burned. So it was running in safe mode.
Old Apr 5, 2005 | 12:01 PM
Evanmb44's Avatar
it means that the hondata is not receiving a signal from the ecu. see if the chip is backwards in the ecu....there is an arrow or a little u thing on one end of the chip and it has to face towards the ecu plugs where they connect to the wiring harness. if you need any more help getting it to work, pm me. i just finished troubleshooting this same problem so everything is pretty much fresh in my mind.
pm me for help if you need it
Old Apr 5, 2005 | 12:02 PM
Evanmb44's Avatar
Default Re: Hondata 2B has blinking red led? (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">Check that the chip is sitting properly inside the socket. Also check the two wire connector from the blue box to the ecu.
Also, this one time I didn't burn the chip correctly and basically put in a blank chip. Took me forever to figure it out since I "thought" the chip was properly burned. So it was running in safe mode. </TD></TR></TABLE>
yes, it could also be the wire that goes from the bluebox to the ecu....and it is a four wire connecter, not two
Old Apr 5, 2005 | 12:44 PM
legendboy's Avatar
Default Re: Hondata 2B has blinking red led? (Turboaddict)
take the blue box out, put it under your tire, drive over it, go inside, download uberdata, burn basemap, go to dyno
Old Apr 5, 2005 | 01:53 PM
Dunc's Avatar
BCICAN
Default Re: Hondata 2B has blinking red led? (legendboy)
I agree....turboaddict is right on
Old Apr 5, 2005 | 03:04 PM
Default Re: Hondata 2B has blinking red led? (Dunc)
the 'U' shape is on the right side, so im assuming the chip is in correctly
Could it be by any chance that the hondata 2b ITSELF is messed up
and not just some wiring issue, burnt incorrectly ,ect?
Old Apr 5, 2005 | 08:22 PM
bump to answer prev. question
Old Apr 6, 2005 | 05:15 PM
Old Apr 6, 2005 | 11:12 PM
Old Apr 7, 2005 | 01:57 AM
tepid1's Avatar
I think you just voided your warranty!
Old Apr 7, 2005 | 08:29 AM
Default Re: (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">I think you just voided your warranty!</TD></TR></TABLE>
what do you mean?
Old Apr 7, 2005 | 11:13 AM
tepid1's Avatar
Default Re: (uHz ! B18C1)
You opened the "Blue Box"....
The 2B
Old Apr 7, 2005 | 11:23 AM
Thurman Merman's Avatar
you think that voided the warranty?
Old Apr 7, 2005 | 11:37 AM
legendboy's Avatar
Default Re: (Thurman Merman)
oh knowing old hondata, if you ever had a problem and doug could prove you opened your case he would void it most likely
Old Apr 7, 2005 | 12:01 PM
dustin's Avatar
Default Re: (legendboy)
Blah doug and the people at hondata have told people to open up the blue box before... to verify if it has the G-sensor chip etc. They aren't going to void your "warranty" unless you destroy the box, drop it in bleach, drive over it, etc. I can't imagine the blue box costs more than $20-$30 to make anyways. They make their money off the "intellectual property" they sell... not the hardware.
You guys seem to really be down on the people @ Hondata. I dunno what the deal is. Oh well.
Old Apr 7, 2005 | 03:52 PM
Default Re: (dustin)
so does anyone know?
Old Apr 8, 2005 | 09:04 AM
dustin's Avatar
U is on the right side of what?
Old Apr 8, 2005 | 10:05 AM
donkiman's Avatar
do u have a basemap loaded?
Old Apr 27, 2005 | 05:57 PM
LSracing94's Avatar
Default Re: Hondata 2B has blinking red led? (donkiman)
you have the wiring wrong
brandonEM1
Engine Management and Tuning
May 9, 2012 07:06 PM
skUnK2jdm
Feb 7, 2008 09:44 PM
itellyawhat
Apr 8, 2006 09:19 PM
jdmeg9
Mar 19, 2006 11:37 AM
99B16Si
Sep 29, 2004 06:53 AM
