honda rod strength?
Old Sep 17, 2006 | 04:33 PM
94hatchvx's Avatar
Default honda rod strength?
ok. i have a 92 cx with a b16.i pulled my motor and began my rebuild and turbo set up. for my bottom end i bought acl race bearings and wiesco pistons. i was going to run stock rods but the more i talk to people the more i want to save and buy rods. my question is will the bottom end hold on 10 to 14 lbs and if it will, how long will the rods stay together?
Old Sep 17, 2006 | 04:48 PM
DRAGLS's Avatar
Default Re: honda rod strength? (94hatchvx)
Keep your revs at a reasonable level and keep your cylinder pressures low and under control and it will last you many years. Its that simple.
Old Sep 17, 2006 | 04:58 PM
94hatchvx's Avatar
Default Re: honda rod strength? (DRAGLS)
ok. im only planning on reving it to no more than 8000.
Old Sep 17, 2006 | 05:00 PM
Garage 808 Hatch's Avatar
expletive man, eagles are 300 bux. dont skimp
Old Sep 17, 2006 | 05:23 PM
94hatchvx's Avatar
Default Re: (Garage 808 Hatch)
300 bucks that i would have to save which means my car being down even longer. i havnt decided yet. im just trying to see how many lbs. and for how long the stock rods are good for.
Old Sep 17, 2006 | 05:44 PM
markaria's Avatar
Default Re: (94hatchvx)
Here is a worst case scenario: You take all this time and spend $$$ on all but rods.... and a stock rod lets go...guess what? Youll be buying new pistons/bearings again (possibly sleeves/block/crank/head too) and how long will the car be down then?
Imo(especially on a boosted motor), if your going to take the time to swap pistons/bearings, then save up the xtra 300 and get new rods.
Old Sep 17, 2006 | 05:52 PM
94hatchvx's Avatar
Default Re: (markaria)
ok. these are for sale right now. good rods? will they go with my crank,bearing,piston set up? they come with arp rod bolts also. http://cgi.ebay.com/ebaymotors...ZWDVW
Old Sep 17, 2006 | 06:22 PM
abnaasefmb's Avatar
the weak part of stock rods are the bolts replace them with arp bolts $50.00.
Old Sep 17, 2006 | 06:32 PM
gsrt nick's Avatar
Default Re: (abnaasefmb)
one of the differences between stock and forged rods are that a stock rod stretches
over time and gets weaker and weaker and keeps strecting
the forged rod might stretch but it will stop and not keep going
also your pistons are full floating pins and you will have to get the stock rods heated and pressed on
just buck up for the rods boost builds alot off cylinder pressure I wouldn't risk it
Old Sep 17, 2006 | 06:42 PM
94hatchvx's Avatar
Default Re: (gsrt nick)
so should i buy those eagle rods from the link i posted? will they go right onto my weiscos?
Old Sep 17, 2006 | 07:14 PM
94hatchvx's Avatar
bump for info
Old Sep 17, 2006 | 07:21 PM
turbosnatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">bump for info</TD></TR></TABLE>
you = should not be boosting
boost = money
money = you dont want to spend
rods = good investment
Old Sep 17, 2006 | 07:23 PM
b16spaz's Avatar
it also depends on how good the tune is, and yes they should fit fine with weisco pistons( worked for me)
Personaly i would just get the rods and wait so that way if u ever want to get more power out of you dont have to tear the block down again and put in stronger rods.
Old Sep 17, 2006 | 07:27 PM
94hatchvx's Avatar
Default Re: (b16spaz)
alright thanks for the info. pics and specs of the build should be up soon.
Old Sep 17, 2006 | 07:36 PM
JSpin's Avatar
a stock rod, forged piston setup is a great setup for a street car, keep the revs in check and go for it
Old Sep 17, 2006 | 08:17 PM
Default Re: (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">a stock rod, forged piston setup is a great setup for a street car, keep the revs in check and go for it </TD></TR></TABLE>
who do u know that drives a honda that keeps their revs in check
Old Sep 17, 2006 | 09:00 PM
Default Re: (turbosnatch)
an ls driver, USUALLY
Old Sep 18, 2006 | 06:05 PM
94hatchvx's Avatar
Default Re: (JSpin)
well i plan on running 10 lbs on the street on 93 octane and 15 lbs at the track on vp 112 race fuel. im thinking what is two more weeks for another paycheck for rods, or paying for it in the long run.
Old Sep 18, 2006 | 06:26 PM
spooncivic1's Avatar
it will probably cost as much to get the stock rods modified to work with the pistons as it would be to get eagles.
Old Sep 18, 2006 | 06:42 PM
94hatchvx's Avatar
Default Re: (spooncivic1)
will these rods "bolt/fit" right up with my wiescos? http://cgi.ebay.com/ebaymotors...ZWDVW
Old Sep 18, 2006 | 06:47 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">will these rods "bolt/fit" right up with my wiescos? http://cgi.ebay.com/ebaymotors...ZWDVW</TD></TR></TABLE>
Yup, those are the ones you want.
Old Sep 18, 2006 | 06:59 PM
94hatchvx's Avatar
Default Re: (NJIN BUILDR)
ok thank you. im gonna buy them now. pics and specs of the build will be posted soon
solorex
35
Feb 28, 2017 03:29 PM
hondaluv!
10
Sep 15, 2014 04:00 PM
civic-r11
Apr 10, 2014 09:53 AM
the.hamburglar
Dec 14, 2006 04:22 AM
importboi22
Mar 8, 2004 07:52 PM
