Honda OEM MAP sensor question
Old Jun 10, 2004 | 06:13 PM
liquidxEG's Avatar
Default Honda OEM MAP sensor question
How does the OEM MAP sensor read pressure? Does it automatically scale for altitude? For instance, in denver Atm. is 12.2 PSI, as opposed to 14.7. SO, would the ECU see 2.5 PSI of boost as atmospheric in denver, since 12.2+ 2.5PSI = 14.7? or does it automatically calibrate itself to detect what the atmospheric pressure is in any given area?
Old Jun 10, 2004 | 06:38 PM
Jared's Avatar
Default Re: Honda OEM MAP sensor question (liquidxEG)
the factory ecu has a baro sensor that it compares the map reading to.
Old Jun 10, 2004 | 07:02 PM
liquidxEG's Avatar
Default Re: Honda OEM MAP sensor question (Jared)
is this reading still effected when running with closed loop disabled?
h23aAccord
Mar 25, 2017 04:53 AM
_Justus
Engine Management and Tuning
Apr 18, 2013 02:08 PM
kell211
Oct 6, 2003 04:07 AM
