holset question
Old Sep 5, 2007 | 01:08 PM
theresyourproblem's Avatar
Default holset question
I just bought a holset HX35 and i cant find out what size exhaust housing I have. Could someone point me in the right direction. I tried typing in the serial numbers on google with no luck. Thanks.
Old Sep 5, 2007 | 01:11 PM
Hondaruss's Avatar
Default Re: holset question (theresyourproblem)
usually inside of the housing towards the flange for the manifold its stamped in there.
Old Sep 5, 2007 | 01:37 PM
Default Re: holset question (Hondaruss)
so i see a spot that says-
E4-01-164. Underneath that it says-
12 8
does that mean its a 12 cm?
Old Sep 5, 2007 | 01:54 PM
gokhan's Avatar
it is written on the inside of the turbine housing
here is a picture
Old Sep 5, 2007 | 03:33 PM
thank you. i appreciate it
Old Sep 5, 2007 | 06:17 PM
Reyke's Avatar
Also when you go to add your oil feed line, be smart don't waste money buying or making a plate to bolt onto the oil feed just buy a 3/8 pipe thread tap and re-tap your oil feed. I currently run a H1C holst with a 16 cm housing on an old school 89 lude with full head work and my spool time is around 3200 when I see just 5 pounds and after that it blows away whats left of my clutch. You'll love this turbo.
Old Sep 5, 2007 | 10:48 PM
90dxhmt's Avatar
Default Re: (Reyke)
You could also just buy the 12mmx1.5 adapter to go to -4 [1/4 JIC] for 5-10 dollars and thread it in
asianspeed
Oct 29, 2005 02:06 PM
iceman24
Jun 25, 2005 11:29 PM
FI-LS
Jun 2, 2005 11:26 PM
MVLZ
Oct 1, 2003 09:40 AM
lucas569
Jan 14, 2002 07:16 PM
