highest rev on stock head b18c1
Old Jan 3, 2003 | 03:49 PM
Cyber ITR's Avatar
Default highest rev on stock head b18c1
is it safe to rev b18c1 to 9000rpm , stock head , built bottom end , tuned properly
Old Jan 3, 2003 | 04:19 PM
CRVRX's Avatar
Default Re: highest rev on stock head b18c1 (VTEC_SiR)
Stock B18C1 head with C1 cams your about on the edge at 8500rpms. Put ITR inner springs on the Exhaust side and you should be good to 8800 rpms with GSR cams.
Old Jan 3, 2003 | 04:21 PM
b18CT's Avatar
you will start to float at about 8500
Old Jan 3, 2003 | 06:15 PM
Cyber ITR's Avatar
Default Re: highest rev on stock head b18c1 (REVTurbo)
what does floating mean ?
Old Jan 3, 2003 | 06:50 PM
BoM's Avatar
BoM
it doesn't close.
Old Jan 3, 2003 | 08:42 PM
jinxproof99's Avatar
New User
Default Re: highest rev on stock head b18c1 (BoM)
i wouldn't go over 8500.
Old Jan 3, 2003 | 08:52 PM
lazy bum shaughn's Avatar
Valve doesn't close in time and it hits your piston and swak bam by motor. That's why you upgrade your valve springs and retainers.
Old Jan 3, 2003 | 09:04 PM
I Like Boost's Avatar
Default Re: highest rev on stock head b18c1 (lazy bum shaughn)
i wouldn't even go over 8300 with stock head.
Do you guys think i'll be fine up to 9000rpm with my gsr cams, skunk2 valves, springs, and ti retainers on my 84mm b18c block built with je pistons and crower rods. t3/t4e 18+ psi all tuned by hondata properly.
Old Jan 3, 2003 | 10:10 PM
Cyber ITR's Avatar
Default Re: highest rev on stock head b18c1 (BEe18SeAONe)
alrite thanks for the replies so far guys
Old Jan 3, 2003 | 11:02 PM
b18CT's Avatar
i already try the type r ecm in my old gsr i didint break anything but i could feel a big lost in power at about 8200+rpm cuz valve was starting to float! i had the type r intake camshaf whit that to!
Old Jan 3, 2003 | 11:08 PM
b18CT's Avatar
good question !i would like to know in this to
i know that for n/a gsr camshaft are not apropriate for 8200+rpm
Old Jan 4, 2003 | 02:56 AM
Tofurky's Avatar
any difference between jdm gsr(sir-g) heads and usdm gsr heads?
Old Jan 4, 2003 | 09:14 AM
b18CT's Avatar
Default Re: highest rev on stock head b18c1 (Ruckus138)
ttt
Old Jan 4, 2003 | 11:38 AM
Mr. Softee's Avatar
I used to go to 8500 ALL DAY with no problems with ITR cams.
dewulf92
27
Mar 13, 2009 12:25 AM
Formula
Mar 16, 2006 08:06 PM
b18bturbo
Aug 17, 2005 06:32 AM
94lsboost
Feb 25, 2005 07:54 PM
MI4eg
Sep 27, 2003 09:27 PM
