High Compression Low Boost
Old Aug 19, 2012 | 04:14 PM
  #26
DDTECH's Avatar
Default Re: High Compression Low Boost
Originally Posted by EsotericImage
im surprised you guys are talking overlap on a boosted high comp build..
I learned that short duration to reduce overlap is best so you dont shoot the boost out the exhaust valves..
but ill keep this thread handy to see where it goes..
That is only true if the head doesn't flow enough, your turbo isn't efficient enough and the rest of the setup has alot to do with it.
All these "real racecars" that are boosting 30-35 psi, they are using some big camshafts with alot of overlap.. it isn't dialed out. This isn't something good for a street type setup, but it will be fine for a all out, 6-12k racecar. IF the setup flows.
Old Aug 19, 2012 | 05:07 PM
  #27
Uncle Dave's Avatar
Its all about a COMPLETE COMBINATION not just a heap of parts thrown together,current turbo's,exhaust manifolds,intake manifold designs,injectors,fuel,management systems,porting,and data that we have all aquired from testing allows high comp turbo setups to be a fun daily driven engines.AND CAM PROFILES that are now on the market
Old Aug 19, 2012 | 05:42 PM
  #28
EsotericImage's Avatar
Retired Moderator
i apologize.. im used to street set ups and research lower power goals and such..
but good info indeed
stefz
Jan 29, 2009 08:22 AM
MyEvo
Oct 6, 2005 05:14 AM
rb08
Aug 26, 2003 07:52 AM
NXAccordTO4B
Mar 20, 2003 09:01 PM
-iLLuZioN-B18C1
Mar 4, 2003 04:46 PM
