help is wanted. need help by tonight to get it running!
i bought an F-max turbo kit for my integra LS. The problem is that the piping that comes off the turbo barely fits b/c it hits the radiator as it comes off the turbo.. i'm wondering if i could, or if they make a 90 degree or 45 degree turbo hose to connect this pipe to the turbo so it doesn't hit the radiator? if so where do they sell them? any suggestions would be helpful on what to do or where they sell them.
thanks
thanks
Home Depot or Lowes has rubber elbow's that you can use in their plumbing isle. I use one on my d16y7 because my throttle body opens straight up and my intercooler piping works on an EX manifold. so I put in that 90* bend and wha-laa. Works perfect. Probably not the best thing to use but it'll work till I get my ex head and intake manifold.
Nick
Nick
atleast your with your f-max kit you didnt have to grind away part of the block that has the engine code on it, because most likely the manifold was not welded correctly, not matter where we placed the turbo it would hit. also our i/c piping, like 3 tubes had to be grinded because they were overlapping eachother. "No Fabrication or hassle" my ***
turbodx97
Aug 27, 2005 09:28 PM
