Help w/ T25 Please. Pics inside.
Old Jun 3, 2005 | 10:12 AM
mp5o's Avatar
Default Help w/ T25 Please. Pics inside.
Well I just bought a garret t25 from a nissan... Thing is... The exhaust housing inlet and the compressor housing outlet is on the same side... Is there any way I can kinda turn it so that they are opposite directions?
Old Jun 3, 2005 | 10:48 AM
mp5o's Avatar
Default Re: Help w/ T25 Please. Pics inside. (mp5o)
nobody knows?
Old Jun 3, 2005 | 10:57 AM
adseguy's Avatar
yes, search for "clocking" or "clock"
It's just called clocking the turbo. Make sure that when it's on the oil return line is no more then 15 degrees off the vertically down so you get a good oil return and won't blow your seals
Old Jun 3, 2005 | 11:03 AM
KtotheEK's Avatar
you need to loosen the two or three bolts on the inside housings of inlet and exhaust of the turbo... its called clocking the turbo
Old Jun 3, 2005 | 11:06 AM
mp5o's Avatar
Default Re: Help w/ T25 Please. Pics inside. (retarded)
Thanks fellas. Wish me luck.
Old Jun 3, 2005 | 11:07 AM
mp5o's Avatar
Hey retarded. Your the guy that sold me the gc coilovers and tokicos. Thanks alot man. They were in pretty good shape. I appreciate it!
Old Jun 3, 2005 | 01:19 PM
ITSME4G63's Avatar
t25's are **** turbo, waste of time IMO
Old Jun 3, 2005 | 01:22 PM
mp5o's Avatar
Default Re: (ITSME4G63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSME4G63 &raquo;</TD></TR><TR><TD CLASS="quote">t25's are **** turbo, waste of time IMO</TD></TR></TABLE>
... Thanks man. This is my first time putting together a kit... I'm looking for no more than 160-180whp. Thanks for the encouragement!
Back on topic.... Does anybody know what bolts I need to take off? I took off the ones on the compressor housing, but the ones on the exhaust housing wont budge.
Old Jun 3, 2005 | 01:43 PM
SOHC_MShue's Avatar
This is for a honda not a dsm
Old Jun 3, 2005 | 03:28 PM
Blanket Jackson's Avatar
I have a T25 on my DSM, spools way to quickly. I know this is your first time, but I guess if u can get the HP you wanna out of it, thats cool. I guess this is going on a single slammer, right? Well, my engine is a tad bigger than a D16, by a bunch, 2.4l here, and I run out of boost pressure at a little over 5,5 grand.
Old Jun 3, 2005 | 03:50 PM
ITSME4G63's Avatar
Default Re: (SlowSpyder)
only the n/t spyders come with a 2.4, your turbo model has a 2.0
and I doubt a t25 will pull hard on a honda, yes I know its for hondas doofus
Old Jun 3, 2005 | 03:51 PM
wantboost's Avatar
Who is Mr Robot?
mp5o, cant drive for **** anyways... the last thing he needs is a turbo sohc
Old Jun 3, 2005 | 05:06 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSME4G63 &raquo;</TD></TR><TR><TD CLASS="quote">only the n/t spyders come with a 2.4, your turbo model has a 2.0
and I doubt a t25 will pull hard on a honda, yes I know its for hondas doofus </TD></TR></TABLE>
I run a wrx turbo on my sohc...about the same size if not smaller than that t25 and I ran a 13.7 on only 8psi so i'm guessing i'm up around 200whp. A stock sohc isn't going to safely push much more power than that. Many people have successfully ran small turbos like this on stock sohc's without problems.
Old Jun 3, 2005 | 05:25 PM
DragSource's Avatar
This turbo is totally different than a Mitsu t25 you guys
It's probably a T25G found most commonly on SR20DET Red Tops -
They spool nicely - and are a great street turbo for the street/junkyard setup.
I bested a 12.812 @ 106 with one of those @ a meeger 7-8 PSI in a Integra LS.
Nice find bro - it's a good snail IMO, and can be attained fairly inexpensively.
Old Jun 3, 2005 | 05:30 PM
mp5o's Avatar
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">mp5o, cant drive for **** anyways... the last thing he needs is a turbo sohc</TD></TR></TABLE>
LOL.... Thanks man.
But back on topic... Do I have to take off the bolts on the exhaust housing also? They wont budge.... I don't wanna strip em.
Old Jun 3, 2005 | 08:11 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (mp5o)
soak it in pb blaster
Old Jun 12, 2005 | 04:40 AM
pramonn's Avatar
Umm....T25!
I'm not sure but its looks like T28 as per this web links
http://www.mjmturbos.com/T286480ar.htm
http://www.mjmturbos.com/AAAmjm2ndpage.htm
ef dino
Aug 2, 2007 09:18 AM
bigbadboy
Apr 26, 2007 07:57 PM
93turbotegSAV
Aug 29, 2006 02:44 PM
99Sivic
Jan 31, 2005 05:14 PM
B18C-RnVA
Aug 20, 2002 10:35 PM
