Help!Tapping FPR Source causes car to bog?
Old Dec 2, 2006 | 05:55 PM
HeedLessInc's Avatar
Default Help!Tapping FPR Source causes car to bog?
I tapped the FPR for the vac source for my WG,BOV,and boost Gauge.today I almost took it to boost but all of a sudden it bogged!The car almost died!Has this happen to you guys before?If I tap into the Brake booster will it effect my braking?I also dont have a missing link right now and the chipped ecu is not installed yet maybe it went to limp mode?Thanks
Old Dec 2, 2006 | 06:26 PM
HiProfile's Avatar
Default Re: Help!Tapping FPR Source causes car to bog? (HeedLessInc)
It was probably limp mode, since it KO's once it sees over 1psi of boost.
As for what to tee off of, some will say they have no issues using the FPR hose, but I never liked that idea. If you use the brake booster hose, you're using a hose with aprox. 9 times the volume (1/8" vs 3/8").
Old Dec 3, 2006 | 10:17 PM
Default Re: Help!Tapping FPR Source causes car to bog? (HiProfile)
Thanks, I'm using check valves(temporary) and it went away!
civic_driver
May 16, 2009 08:46 PM
crawlin
Nov 19, 2007 09:22 AM
99teggsr
Jun 1, 2005 09:39 PM
blackccoupe
May 18, 2004 07:26 PM
FastNFurious
May 7, 2003 01:00 PM
