help.. stuck installing digital6 etc
Old Jul 17, 2002 | 10:16 AM
Midwestrider's Avatar
Default help.. stuck installing digital6 etc
FYI:
i did do a search and found this:
https://honda-tech.com/zerothread?id=172857 , i im'ed itr206 and he was not sure how he did his...
i have the hvc blaster coil-pn#8252
i have a digital6, and also the modded distribtor cap
they way i wired it is:
red wire = 12+ to battery
black wire= ground on battery
orange wire= positive side of msd coil
black wire= negative side of msd coil
trigger wires..
white wire= going to negative side were oem coil was
red wire= *tried 2 differnet ways*
1st connected *red wire* to the ring termial that came off oem coil w/ black/yellow wire connected normally and taped connection.... car wouldn't start
2nd connected red wire to a switched 12+ and left the black/yellow connected as it normally is... still wouldn't start
3rd connected red wire in place of black/yellow and still no go
the instructions says for the trigger wires, (black and red) the red goes to 12v switched, and black to negative were oem coil was?
any help??
Old Jul 17, 2002 | 10:59 AM
boostaholic's Avatar
Default Re: help.. stuck installing digital6 etc (Midwestrider)
I have that red wire tapped into the black/yellow 12v switched wire going into the distributer and it works fine. Do you still have your stock internal coil in the distributer?
[Modified by boostaholic, 8:01 PM 7/17/2002]
Old Jul 17, 2002 | 11:30 AM
Default Re: help.. stuck installing digital6 etc (boostaholic)
no when i had it all connected (msd equipment) i had the stock coil removed.
when the stock coil removed the black/yellow wire has a 2nd wire which is has a end with a ring terminal were it was connected to the + side of oem coil.
i attached the red wire around the ring terminal and taped it.
connect the msd cap and connected plug wire to msd coil and still didn't start
Old Jul 17, 2002 | 11:36 AM
PM-Performance's Avatar
that positive oring wire should be extended directly to 12v source . that was the other wire i had comingout of the cap .
and the neg of the stock coil io forget which color was that other wire coming off the dig 6, once you got that you should be good to go . . . . its the pos wire from the old coil that permits the car to start. . . thats where i fucked up on mine. the 1st block of instructions in the manual should be the best diagram that msd gave you .
Old Jul 17, 2002 | 11:56 AM
oh and check your fuses. . . . once you **** up the 1st time , your starter fuse is gone. , so that might be another reason . check that too
Old Jul 17, 2002 | 12:09 PM
Default Re: help.. stuck installing digital6 etc (itr206)
ok,
yah when i connected everything back to stock today, i blew that fuse.. replaced and car started
so you say to connect the white wire were the the (white/blue) from oem coil was.
connect red to the black/yellow tab
and the ring terminal from black/yellow to switched 12v...
if so i will try 1st after work.. which will midnight
thx
[Modified by Midwestrider, 11:30 PM 7/17/2002]
Old Jul 17, 2002 | 12:12 PM
no dont touch the tab. . . . that black and yellow wire goes direclty to swxed 12v.
how many wires do have coming from the msd left?
i havent done this in so long, but can remmber if i have something to picture. . what wires are left.
Old Jul 17, 2002 | 12:26 PM
SilverS's Avatar
http://www.msdignition.com/pdf/MSD_Digital_6.pdf
this is the complete instrustructions on how to install the digital 6, its about 4megs and u will need acrobat reader, but its got pictures
HTH
Old Jul 17, 2002 | 01:57 PM
Default Re: help.. stuck installing digital6 etc (2000EX)
I have the the instructions.. thx 2000ex
I have read the multiple times and am still stumped..
Old Jul 17, 2002 | 02:51 PM
the only wire i am stumped on is were in the hell the red trigger wire is supposted to go.
i will post pics to explain what i am taking about..
Old Jul 17, 2002 | 10:13 PM
coil222's Avatar
this midwestrider, i am just at a friends house using his digtial camera for some pics..
the stock coil with + wire removed from oem coil
the oem coil removed with the black/yellow wire (goes to (+) of oem coil
this is the way this should be wired correct?? the red and black are the trigger wires from the msd unit.
the black/yellow is supposed to connect to 12v switched now correct?
please help me out guys this **** is driving me up the wall!!!!
Old Jul 17, 2002 | 10:30 PM
Default Re: help.. stuck installing digital6 etc (coil222)
The black/yellow wire still needs to be connected to the ICM inside the distributer. Tap the Red 12v switched wire from the MSD box to this black/yellow wire and connect the White wire from the MSD box to the post where the stock coil negative terminal wire went to. Kinda confusing but hope that helps.
Old Jul 17, 2002 | 10:36 PM
coil222's Avatar
OK,
so were the red wire is connect the black/yellow with the red wire, thus providing the red with a 12v switched signal???
if so i am going to try that now
Thx boostaholic
midwestrider..
Old Jul 17, 2002 | 10:47 PM
Yeah, that black/yellow wire is a 12v switched wire that sends a 12v positive signal through when you turn the key to the ignition position. The red wire from the MSD box needs to tap into that signal and that black/yellow wire still needs to go to the ICM to give it power so don't disconnect it.
Old Jul 18, 2002 | 02:09 AM
Ok update
I got curious and tested wire to verfiy I was getting signal to them.
I am getting pwr/ground to main lead. The orange and black wires are connected to the msd coil correctly.
I have the msd coil grounded correctly also.
Test the black/yellow wire with is 12v switched.
So wiring is ok.
Thing is I think the ignition is bad out the box, when looking at the unit connected in "on" position the led doesn't even light up.
So I checked my buddy's setup (coil222) he also has a digitial6 and msd coil, in the "on" position the led should light up.
Oh well gotta call msd in the morning and see what to do on getting this damn replace. new out the box and the **** is broke...
thanks for the info guys...
Old Jul 18, 2002 | 06:55 AM
turbosol's Avatar
What do you mean that the MSD coil is grounded correctly, the coil should only be connected to the MSD box. If you grounded the negative side of the coil this could verywell be your problem.
Old Jul 18, 2002 | 07:09 AM
now what i did is left the black and yellow wire in the tab and that oring i tapped a wire into that and ran that wire to the 12v sweitched . you need to still have that black and yellow to that tab. it branches off to soemthing else.
fix that and it will work , cuz thats who i have mine.
Old Jul 18, 2002 | 07:20 AM
turbosol:
with msd coil you have to connected the +/- wire from the msd unit. and also ground this coil-hvc blaster coil #8252
itr206:
what is did is i connected the black/yellow wire, and striped some the wire coating back and attached the red wire.
the black/yellow is switched 12v, i verfied with my test light... still didn't work
i get no led on the side of the digital6
Old Jul 18, 2002 | 07:34 AM
then either a fuse is blown again or something else is wired wrng . . . the cap part is right now.
do you have the dials on the msd box set to 4cyl?
Old Jul 18, 2002 | 09:16 AM
Horray!!!
The problem is a bad coil.. I tested for spark and got nothing so I wired into the OEM coil.
Wired and car started.... Yah...
The problem with the coil is on the tower were the plug wire goes, there is a crack about along both sides.
Again thanks boostaholic, and itr206
So I gotta send back the coil and get a new one.
Old Jul 18, 2002 | 09:28 AM
no prob dude. . . btw, get a blaster ss coil they are made for the digital 6, they work best with them .
Old Jul 18, 2002 | 10:44 AM
Glad you found the problem, i was about to propose you test the coil next. An easy way to see if your coil is working if you know you have all the wiring correct is take the lead wire off the external coil and spin the motor over. You will see hella spark jump from the positive and negative posts into the lead wire boot. Anyway, just call up MSD and tell them your problem. They have great customer service and will warranty out your coil free of charge. My 6AL crapped out on me once on the way to a race and they took care of everything
raidacaipo
May 12, 2008 08:07 PM
jumpman83
Oct 23, 2005 03:24 PM
1.8
Audio / Security / Video
Mar 6, 2005 04:40 PM
giser
Sep 5, 2004 07:48 AM
LuderX
Jan 13, 2003 05:49 PM
