HELP:SELECTING THE RIGHT MANIFOLD AND DOWNPIPE
Old Aug 26, 2011 | 11:14 AM
Dc4LsTeG's Avatar
EK9
Default HELP:SELECTING THE RIGHT MANIFOLD AND DOWNPIPE
I need help picking out the right manifold and downpipe to use with my turbo it will be going on a b18c5.. the turbo is a turbonetics i believe its a .60, im new to turbo so if you could also explain how to measure everything to see what size it is..
I need to know what manifolds and downpipes id be able to use with my turbo on a b18c5 if anyone could help me out
heres the pics of it
Old Aug 26, 2011 | 02:05 PM
EsotericImage's Avatar
Retired Moderator
Default Re: HELP:SELECTING THE RIGHT MANIFOLD AND DOWNPIPE
http://www.spoolinperformance.com/-c...268677b5d2fa52
Phil @ spoolin:
http://www.go-autoworks-store.com/go...manifolds.html
Greg: Ph: (334)467-4171
https://honda-tech.com/forums/forced-induction-49/
plenty of HT sponsors with great deals.
you need to know if the turbo will be mounted with driver or pass side exit and if you keep AC then a log manifold is what u need but will restrict power over 6k rpms.
If you delete the AC, then you have room for a ramhorn or something with good flow.
Edit.. make sure you run a larger exhaust from cat-back. you want to let the exhaust flow as fast as possible w/o restriction. Personally, i use a 2.5" downpipe (for AC reasons) and 3" all the way back and a resonator with cat delete.
Old Aug 26, 2011 | 02:20 PM
Casey's Avatar
thats a t3 housing inlet, exit is 5 bolt flanged. shameless plug:
http://www.hondamarketplace.com/show....php?t=2971258
Old Aug 26, 2011 | 02:32 PM
Retired Moderator
looks great except for the non 38mm
Old Aug 26, 2011 | 02:39 PM
Dc4LsTeG's Avatar
EK9
Phil @ spoolin:
https://honda-tech.com/forums/forumdisplay.php?f=49
Thanks for the response..I will message the sponsers you recommended and see what they can get for me..my ac is already deleted just have ps..I believe I hafta get a downpipe that exits on passenger side right by the way the turbo would mount?or can you flip it either way?I already have a full bc spec 2 w/ test pipe on the car..I was thinking something maybe like this?any comments?
http://www.fmpracing.com/product_inf...roducts_id=414
Are you talking about my turbo?what do you mean by this?and will that manifold and downpipe work for me?
Srry guys if I sound like a noob I'm just trying to get into turbo for the first time..thanks aging for the responses.
Old Aug 26, 2011 | 03:02 PM
Casey's Avatar
yes. the back housing/exhaut housing of your turbo is a t3 inlet so you need to find a t3 manifold for it. the exit of the housing has 5 bolts so the downpipe will have to be a 5 bolt design. that mani and downpipe will definitely work for you
Old Aug 26, 2011 | 03:23 PM
Dc4LsTeG's Avatar
EK9
Don't I need a downpipe that exits on the other side then yours does?or could I flip the whole turbo around?thanks again for your help..
Would the manifold and downpipe that I posted a link to work with my turbo?
Old Aug 26, 2011 | 03:57 PM
Casey's Avatar
you need a downpipe that is designed to work with the manifold you buy. it can be drivers side or pass side exit. that manifold you post is a piece of junk, and is going to crack.
Old Aug 26, 2011 | 04:22 PM
Retired Moderator
that whole set up is junk.. the flange is always welded backwards on those things.. cheap chinese knock off crap!
Old Aug 26, 2011 | 04:38 PM
Dc4LsTeG's Avatar
EK9
Alright I figured just wanted to see...I know the downpipe needs to match the manifold but which side do I need the downpipe for?either the driverside exit or passenger side exit or can I turn the turbo either way depending on the downpipe I get.
Thank you guys again for the help
VTEC_PRODUCTION
Sep 10, 2007 09:20 AM
PlayDepot
Jun 3, 2005 04:14 PM
turboekcivic
Apr 27, 2003 03:48 AM
