HELP!!! Replaced headgasket, still doing the same thing!
Ok, I just changed the headgasket on my 97 prelude due to the motor was overheated and blown. I fired it up today, it sounds weird, the way it cranks is not like before, it's supposed to be like "chu chi chi chi"-Fire. now it's like "chu chi"-Fire. got what i'm saying??
it idles and revs fine, but same sympton like before, lots of white smoke coming out from the exhaust. fresh Mobil One turned into milkshake in less than 1 minute.
bad compression on all four cylinders:
#1 120psi
#2 90psi
#3 90~psi
#4 140psi
AAAAHHHH.... WHAT THE FVCK IS IT??? someone please help me!!!
#1 120psi
#2 90psi
#3 90~psi
#4 140psi
AAAHHH... hope not... but, i did hear some metal scratching noise when the motor is blown... if the sleeve is cracked, is it still repairable?
cause? the lower radiator hose popped and lost all the coolant, I kept driving it for at least 30 mins after i found out the car was overheating, i believe i traveled for at least 30 miles with no coolant.
I did wipe off all the dirt from the head and the deck before i put them back together. I don't see any damage to the head and the deck. If it's #2 and #3 cylinders, the cylinder wall looked very smooth, i set piston #1 at TDC before i pull the head off, so I could see the whole cylinder wall on #2 and #3.
That hurts to just read.
But I can only guess.
vipokc
Feb 4, 2009 06:57 AM
