Hey all... this is my first post here. I have a 94 gsr and bought a Drag gen III turbo kit w/ Tial upgrade. I also got JE 9.5:1 pistons and Crower rods. I am planning to pull the engine myself and get it resleeved and the pistons and rods put in by a shop...possibly by dynamic autosports. I then plan to put the engine and turbo in myself. I know i probably need new injectors. I do have a vafc to help with the fuel. I just need help with what other parts and info i need before i get started.
thanks for all the help guys.
vafc would be nice but hondata would be much better.
If you plan on putting that much money into your block then you shouldn't skimp on the engine management. Get hondata or some kind of engine management that allows fuel and timing control. You will definitely need larger injectors if you want to see full power potential. I would start out with some 750cc injectors or larger. If you plan on running stock boost levels with that kit then theres no need to build the bottom end like that.
