help me pick injectors
Old Oct 20, 2005 | 06:50 PM
second edition's Avatar
Default help me pick injectors
setup....
dohc zc
greddy15g kit
jrc intercooler,2.25 in piping
hallman mbc
walbrow255,b@m fpr and lots of other stuff i dont feel like trying to remember
Im running 7lbs tuned on crome and im going to remove the exhaust and run a dump and i want to raise the boost to 10lbs fot the rest of the fall untill the car goes away for winter and i redo some things this next spring(manifold,downpipe and full 3in) Im running stock injectors now and my tunner says there maxed out
here inlies the confusion...i was told the stock ones are 240s.
here are some options off the top of my head;
dsm440s with resistor box
prelude/accord (340?) with resistor box
used rc 310 from greddy kit
or paying out the *** for some rc's brand new
Also, how do i identify which honda injestor is which,are there numbers on them?a shop owner here in town has a box full of random honda injectors and he said i can go though it, but he doesnt know which are which..thanks,sorry for the long post
Old Oct 20, 2005 | 07:04 PM
Dunc's Avatar
BCICAN
Default Re: help me pick injectors (second edition)
do it right the first time...get 1000's. Boost is addicting, just remember that.
Old Oct 20, 2005 | 07:06 PM
Default Re: help me pick injectors (Dunc)
is there such a thing as too big?....i dont plan on ever going over 10lbs..i dont wana build the block
Old Oct 20, 2005 | 07:18 PM
N20civicB18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">do it right the first time...get 1000's. Boost is addicting, just remember that.</TD></TR></TABLE>
Thats what I did... but im on a stock motor and already at 63% duty cycle... Think I will need to go bigger after my build
DSM 450's will be fine for you.
Old Oct 20, 2005 | 08:21 PM
KeyserSoze's Avatar
x2
Old Oct 20, 2005 | 08:24 PM
civicb18c's Avatar
too addicting....wish i never boosted cuz im broke. LOL so damn fun!
Old Oct 20, 2005 | 09:23 PM
_gurusan_'s Avatar
Default Re: (civicb18c)
IMO get some tunertoys injectors. THey drop straight in without any extra boring or wiring and are BRAND NEW. Also flow balanced wiht 1% tolerances.
200 bucks new..i'd say good dela
Old Oct 20, 2005 | 09:55 PM
Default Re: (_gurusan_)
ima look into that...thanks
edit;
whats the diffrence between low and high impedience, and would 450s or 550s be better...sorry,this is something i dont know much about..still doing research
Old Oct 20, 2005 | 10:05 PM
adictionbass's Avatar
Default Re: (second edition)
the short answer is high impedience is what most of our cars run. Low impedience you would need to use a resistor box. also described as 'saturated' or 'peak and hold'
do a serch for the technical difference
Old Oct 20, 2005 | 10:14 PM
Default Re: (adictionbass)
just searched 10 pages..came up with some info, but yours was the best
Old Oct 23, 2005 | 06:58 PM
Old Oct 23, 2005 | 07:22 PM
_gurusan_'s Avatar
Stop bumping and buy tunertoys. Trust me they are the best for the $$.
Old Oct 23, 2005 | 07:27 PM
i am buying them.I just dont know if i should get 450s or 550s......just bumping for more info
Modified by second edition at 4:42 AM 10/24/2005
Old Oct 23, 2005 | 07:43 PM
BlueShadow's Avatar
adictionbass's post may have confused some people. Just so there isn't any confusion:
saturated is another name for high impedance injectors
peak and hold is another name for low impedance injectors
If you are running a peak and hold injectors make sure you install resistors or a resistor box. The reisistors need to be installed so that you dont fry the injector drivers (fry your ECU) or that you dont fry the injectors themselves. The injectors may or may not run without a resistor box/resistors installed. But sooner or later you'll fry the injectors/ECU cause they are getting too much voltage or current (I can never remember which one, but I think it's voltage).
Old Oct 23, 2005 | 08:40 PM
goodfella1's Avatar
Default Re: (BlueShadow)
Old Oct 23, 2005 | 08:53 PM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by second edition &raquo;</TD></TR><TR><TD CLASS="quote">i am buying them.I just dont know if i should get 450s or 550s......just bumping for more info
Modified by second edition at 4:42 AM 10/24/2005</TD></TR></TABLE>
Bigger the better. If you dont have a choice, and to choose between those two. Get the 550cc
Old Oct 23, 2005 | 08:59 PM
Default Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik &raquo;</TD></TR><TR><TD CLASS="quote">
Bigger the better. If you dont have a choice, and to choose between those two. Get the 550cc </TD></TR></TABLE>
there the same price so ill be buying the 550s...i like the idea of a clean install without wiring anything...thanks for the help
eglslsd
Jun 30, 2007 05:59 PM
RubenPrelude
Jan 22, 2007 04:12 AM
egizzle8
Mar 10, 2004 02:22 PM
