help me diagnose my problem...
Old Oct 7, 2005 | 09:16 AM
DriveSlowHomie's Avatar
Default help me diagnose my problem...
when i turn on my car, smoke white smoke comes out until u drive it for awhile...i know its burning coolent...last time i opened up the mani to see where i was leaking fluid from, and i saw coolent residue all in the runners and in the plenum...the only thing i could think of was the throttle gasket, so i changed it...it started recently smoking again...where else can it be leaking from?...im pretty sure its not the headgasket because compression still reads fine and there is no water in the oil...also turned it on with the rad cap off and no bubbles...is it possible that there mite be a crack or something in the mani?...using the skunk2 manifold
also will burning cooling mess with the a/f ratio?...still safe to drive correct?
Old Oct 7, 2005 | 10:08 AM
choiboiracing's Avatar
Default Re: help me diagnose my problem... (cmGSR916)
this might be a solution? intake manifold gasket? there is coolant running next to the thingy? check it out?
Old Oct 7, 2005 | 08:13 PM
Default Re: help me diagnose my problem... (choiboiracing)
no its not the IM gasket...at first i thought it was and opened it up...then found coolent in all four runners and in the plenum of the mani...i also changed the gasket to a profab...someone help me out
Steezer
Nov 3, 2011 03:47 PM
93delslow315
Apr 25, 2010 01:42 PM
Ignitecivic
Jan 7, 2005 12:36 PM
Driven
11
Oct 29, 2004 11:41 AM
redrum eg6
May 11, 2004 04:40 PM
