HELP!! lsvtec build
Old Nov 13, 2008 | 05:36 PM
drift93's Avatar
Default HELP!! lsvtec build
I recently started an ls vtec build and i am stuck trying to figure out if i should sleeve it the bore is going to be stock bore with .20 over so 81.50 mm i am shooting for 450-500whp so do you guys think i should sleeve it or no? any help is greatly appreciated
Old Nov 13, 2008 | 06:55 PM
mnskateboarder's Avatar
Default Re: HELP!! lsvtec build (drift93)
yes sleeve it
Old Nov 13, 2008 | 07:02 PM
crooklyn_outlaw's Avatar
anything more then 400 you should sleeve
Old Nov 13, 2008 | 08:32 PM
Ruben19's Avatar
sleeving a must when you going that high.
Then you dont have to worry something blew inside the motor.
Old Nov 13, 2008 | 10:25 PM
FULLYBUILT2.0's Avatar
stock sleeve should be fine......j/p.....i seen different honda motors break the 400-500hp with stock blocks but the cars were tune so good there mama was there watching it too...aha...if your looking for something daily drive, you should get it sleeved....getting it sleeves will help u from blowing your motor apart n it will let u boost a lot more with no worrys.....
Old Nov 13, 2008 | 11:42 PM
98vtec's Avatar
moderator emeritus
why is this in the All Motor section?
Old Nov 14, 2008 | 02:36 AM
drift93's Avatar
i dont know this is the first place i decided to put it i never thought about putting it under forced induction sorry about that
EDIT: thanks for the help guys
vroomvroomjdm24
Nov 18, 2015 01:58 PM
rdssk8rcs1
Aug 31, 2008 12:28 AM
crvtkllr
Dec 4, 2006 05:35 PM
Hondatron
Jun 11, 2006 08:42 AM
slowsi00
Dec 6, 2002 04:30 PM
