HELP LS turbo motor smoking.
Ok i installed my ls turbo for almost a month now. I been having problems with it. Fixed most of the problem but this one i cant figure out what is wrong with it. From inside my motor it is blowing out a lot of white smoke. If i hit the gas more white smoke shoots out. The check engine light just flew on today and the code was 73 which is random misfire cylinder 3. What can be the problem and how can i fix it. Please help.
white smoke from the muffler would be head gasket right
if its a mis fire it could be detonation or pre ignition i dunno
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboInteg95 »</TD></TR><TR><TD CLASS="quote">Just curious but what's your fuel setup?</TD></TR></TABLE>
I have a 12:1 FMU
255 walbro fuel pump
B&M fuel regulator
stock injectors
blox missing link
and a s-fac II
I want have not tuned the car yet but i will after i fix all these lil small problems. Am I missing anything???
I have a 12:1 FMU
B&M fuel regulator
stock injectors
blox missing link
and a s-fac II
I am only boosting 5 psi right now 9 psi will be in two weeks.
I have a T3/T4 Turbonetics turbo
blox manifold
two slim fans for A/C and radiator
2.5" turbo piping
3" downpipe with 3" straight pipe exhaust
blitz BOV
2.5" dump pipe
Tail waistegate
iunno wat kind of innercooler but its about 9" in hieght 6-7" in width
blox manifold
2.5" turbo piping
blitz BOV
2.5" dump pipe
Tail waistegate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wes7side5o »</TD></TR><TR><TD CLASS="quote">Ok i installed my ls turbo for almost a month now. I been having problems with it. Fixed most of the problem but this one i cant figure out what is wrong with it. From inside my motor it is blowing out a lot of white smoke. If i hit the gas more white smoke shoots out. The check engine light just flew on today and the code was 73 which is random misfire cylinder 3. What can be the problem and how can i fix it. Please help. </TD></TR></TABLE>
is it coming from your valve cover? cuz if so its blowby. check your compression across all four cylinders. maybe your ringlands cracked.
476 whp / 323 tq @ 17 PSI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wes7side5o »</TD></TR><TR><TD CLASS="quote">I want have not tuned the car yet but i will after i fix all these lil small problems. Am I missing anything???</TD></TR></TABLE>
the tune should fix the misfiring problem. there are numbers of problems that are fixed when the motor is tuned correctly. for example, with the greddy blue box i threw the misfire codes too and after ditching that box to get a tune, no more misfires to expect. the ignition, fuel, and timing is adjusted correctly to your set-up after a good dyno tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wes7side5o »</TD></TR><TR><TD CLASS="quote">From inside my motor it is blowing out a lot of white smoke. If i hit the gas more white smoke shoots out.</TD></TR></TABLE>
white smoke = blown headgasket, dun't hesitate at all and fix that problem ASAP before your motor goes. a compression test and leakdown test would target the problem easier
if you still having problems, let me kno. im local to san diego too. another LS turbo
white smoke? i had that same problem... did a compression check, it was the piston ring. Hope its not your piston ring... Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93NTEGLS »</TD></TR><TR><TD CLASS="quote">
is it coming from your valve cover? cuz if so its blowby. check your compression across all four cylinders. maybe your ringlands cracked.</TD></TR></TABLE>
ringlands and rings causes black smoke from oil. the white smoke with a tint of blue is from the gasket.
remove your exhaust manifold as well and check for oil in the manifold. if so, then the rings/ringlands are bout to go
Just took apart my manifold yesterday and everything was fine. I drove the car before and everything seemed fine. Just now it has been throwing out a lot of white smoke out of the vaulve cover. Car still drives but just spits out a lot of white smoke. Before a lot of white smoke came out of the exhaust but that stoped and this started a day later.
Are you at least running the GSS342 Walbro? I really always suggest using the Bosch inline with an FMU. They tend to work better at the high pressures. Although this doesn't answer your question, it may be part of the cause.
It's wierd for the head gasket to blow or the rings to crack because the motor was just rebuilt to new. We bought and replaced everything inside of it. Everything was fine until we installed the turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccfab »</TD></TR><TR><TD CLASS="quote">the turbo is what cooked your motor. sounds liek definate you got owned from a stupid fuel setup</TD></TR></TABLE>
exactly, this topic has been covered thousands of times. smoke out of your valve cover on a stock motor with a bad fuel setup, untuned will be broken ringlands 99% of the time
Boost doesnt kill your motor, detonation does and with yours i guess 5psi is all it took. goodluck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wes7side5o »</TD></TR><TR><TD CLASS="quote">Man this suks because I just had my motor rebuilt. Only put about 10k on the motor.
TUNE the next time
</TD></TR></TABLE>TUNE the next time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC »</TD></TR><TR><TD CLASS="quote">TUNE the next time
I was just going to tune it but first i had white smoke leaking out of the manifold area then just fixed that. Then found out i had a 5 psi spring not a 9 so i was waiting for the 9 psi spring to come in. Then I had the problem where the turbo wasnt boosting right. So then i just fixed tat. Was going to tune it in a week once spring comes in but not i got this problem to deal with. What can be a good fuel setup because i was told wat i had was a good setup already????
</TD></TR></TABLE>I was just going to tune it but first i had white smoke leaking out of the manifold area then just fixed that. Then found out i had a 5 psi spring not a 9 so i was waiting for the 9 psi spring to come in. Then I had the problem where the turbo wasnt boosting right. So then i just fixed tat. Was going to tune it in a week once spring comes in but not i got this problem to deal with. What can be a good fuel setup because i was told wat i had was a good setup already????
I was just going to tune it but first i had white smoke leaking out of the manifold area then just fixed that. Then found out i had a 5 psi spring not a 9 so i was waiting for the 9 psi spring to come in. Then I had the problem where the turbo wasnt boosting right. So then i just fixed tat. Was going to tune it in a week once spring comes in but not i got this problem to deal with. What can be a good fuel setup because i was told wat i had was a good setup already????</TD></TR></TABLE>
ditch the FMU and missing link and get some bigger injectors (440cc,550cc,etc) and look into getting hondata or EMS if you have the money or FREEware like Crome, uberdata, neptune
Honestly the misfire code is the least of your problems right now. Although i guess technically it could cause that. Either way, ditch that fmu. FMUs + Walbro pumps = no good.
ok since u guyz have more experience with ls turbo ima ditch the walbro fuel pump and the fmu but wat exacally should i get for the fuel management
Boosting on an untuned setup is like ******* a hot girl YOU KNOW has herpes.... it may be fun at the time.. but you know your gunna be in trouble in like 2 weeks
You did use ARP headstuds when you rebuilt right?
