Help identify problem with built block <56k no way>
Old Mar 1, 2005 | 09:34 AM
  #26
tgreaves's Avatar
Default Re:
Possibly a worn thrust washer would be my guess..
Old Mar 1, 2005 | 10:00 AM
  #27
BoostingSnail's Avatar
Default Re: Re: (tgreaves)
This could happen if the block over heated or some other spontaneous problems..but it's probably very rare..anyways im referring to a shift in the cylinder which would shift the piston in the bore making the small end of the rod ride against the one side of the piston and it could also **** the rod to one side making those bearings appear they way they are..just something to throw out there for you to think about..sorry to hear about your mishap
Old Mar 1, 2005 | 10:05 AM
  #28
Unsivil_audio's Avatar
Default Re: Help identify problem with built block <56k no way> (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">I wonder if something clogged the oil passage to that particular bearing? </TD></TR></TABLE>
I agreed, that would be my guess. Also dude, no two ways about it, that motor is gonna have to come back apart and that crank will have to be turned down. So you should get on that and take some more pics while inspecting further.
Also, this is kinda a long shot, but maybe that rod is slightly bent putting some weird load on one side of the bearing.
Old Mar 1, 2005 | 01:58 PM
  #29
Blackack26's Avatar
Default Re: Help identify problem with built block <56k no way> (Unsivil_audio)
I just finished getting the motor out of the car. I'm about to go strip it down right now....
I'm taking the block to the local machine shop tomorrow morning to inspect the damage.
Old Mar 1, 2005 | 02:18 PM
  #30
BlackT5's Avatar
Well, he did find the end of a dipstick stuck in the oil pickup.
Old Mar 1, 2005 | 04:37 PM
  #31
MrBui's Avatar
Default Re: Help identify problem with built block <56k no way> (BlackT5)
what crank is that? and what bearings are you using? i know that a gsr crank has smaller journals than si and ls.... so if you put si bearings in a gsr motor it would rub badly...gsr rods on a si crank give you a lot of play also
Old Mar 1, 2005 | 04:51 PM
  #32
Blackack26's Avatar
Default Re: Help identify problem with built block <56k no way> (MrBui)
block is a b18a and im assuming the crank is also. I didn't assembly the block, but was told they are oem bearings.
Old Mar 1, 2005 | 04:55 PM
  #33
MrBui's Avatar
Default Re: Help identify problem with built block <56k no way> (Blackack26)
well i assumed my crank was a gsr but ended up being an si... that gave my rods room to move side to side....check your stroke on the crank
Old Mar 1, 2005 | 05:16 PM
  #34
sheepey's Avatar
Hmmm Well thats weird. I can vouch for the block thats for sure. I saw this thing runnin and it ran great right before it was tookin out.
Old Mar 2, 2005 | 09:34 AM
  #35
Blackack26's Avatar
Default Re: (sheepeg3)
I just got back from the machine shop and have come to a conclusion as to what has cause the problem.
The machinest said it was due to too tight of clearance between the wrist pin and small rod end, as well as too much clearance on the big rod end. The crank is no good due to the large ridge the rod wore into it, the rod is burnt badly, and the piston also needs to be replaced because of the scarring.
EDIT: Forgot to mention the machinest also said wrong bearing sizing could aided the damage as well as mabye a clog in the oil passage.
Pics of the crank:
nasty scarring
Modified by Blackack26 at 12:31 AM 3/3/2005
Old Mar 2, 2005 | 01:19 PM
  #36
JDMCRX's Avatar
Default Re: (Blackack26)
thats shitty man
Old Mar 2, 2005 | 01:43 PM
  #37
powerofdreams8's Avatar
Default Re: (JDMCRX)
So what is your recourse with who sold you the block? I would always be weary of anyone selling a barely used built motor.
Old Mar 2, 2005 | 03:36 PM
  #38
Blackack26's Avatar
Default Re: (powerofdreams8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by powerofdreams8 &raquo;</TD></TR><TR><TD CLASS="quote">So what is your recourse with who sold you the block? I would always be weary of anyone selling a barely used built motor.</TD></TR></TABLE>
Trying to work something out...
He said the block ran beautifully before he sold it, and I do believe him. He has plently of vouches and is respected. However it knocked the second it fired up.
I dont know if mabye something during shipping aided to this? mabye it was knocked real hard against the crank pulley? The pulley was chipped in a few places and it was packaged rather shitty.
Old Mar 2, 2005 | 04:46 PM
  #39
BlackT5's Avatar
I vouch for the fact it knocked when it was first started. Even though it did get quieter when it warmed up all we did was swap the blocks. It had plenty of oil.
Old Mar 2, 2005 | 07:04 PM
  #40
doublej's Avatar
FWIW, the pics on first page show #3 rod installed w/ bearing tang to intake and #4 rod tang to exhaust. Assume rod cap was installed correctly?
egpwns
Jan 4, 2008 03:29 PM
egpwns
Dec 29, 2007 07:41 AM
hondaracer93
Feb 4, 2006 01:52 PM
mojoGSR92
Feb 21, 2002 07:19 PM
mojoGSR92
Feb 21, 2002 04:36 PM
