Help with F.I. problem I"m having.
Old Mar 15, 2003 | 07:09 PM
gsr96's Avatar
Default Help with F.I. problem I"m having.
Alright, today I was driving around and my jrsc was performing great. Then, I stopped and talked to some friends and when I left, it did'nt work right. It would still be in vaccumm when it was supposed too, but when I floored it, it just went to 0 and stayed there, it would'nt make any boost. Then when I got into vtec it would make about 4lbs. of boost, instead of the 7 it is supposed to make. But until I got to about 5k rpm's, it won't make any boost. What do you guys suppose is the problem?
Old Mar 15, 2003 | 07:11 PM
civictypenos's Avatar
Default Re: Help with F.I. problem I"m having. (gsr96)
have you checked your belt?
Old Mar 15, 2003 | 07:14 PM
bryan305's Avatar
Default Re: Help with F.I. problem I"m having. (civictypenos)
Well, it's either the belt or you have a leak to your boost gage.
Old Mar 15, 2003 | 07:32 PM
gsr96's Avatar
Default Re: Help with F.I. problem I"m having. (bryan305)
The belts all seem to be in place. Would a leak to teh gauge cause it not to boost until vtec?
Old Mar 15, 2003 | 07:48 PM
stnwag0n's Avatar
Does it feel like its not boosting? or does it just show that its not boosting?
Old Mar 15, 2003 | 07:56 PM
gsr96's Avatar
Default Re: Help with F.I. problem I"m having. (turb0accrd)
It shows its not boosting, and you can deffinantely feel that it is not boosting.
Old Mar 15, 2003 | 08:37 PM
bryan305's Avatar
I'd say pop your hood and rev your engine using the tb. Try to put your hand around the s/c and head...see if you can feel a leak.
Old Mar 15, 2003 | 08:54 PM
gsr96's Avatar
and assuming I find a leak, how hard is it to fix?
Old Mar 18, 2003 | 01:17 PM
gsr96's Avatar
Ok, I believe that I need to retension my belt. My question is, how do I retension my s/c belt?
Old Mar 18, 2003 | 03:57 PM
gsr96's Avatar
bump to learn how to retension my belt.
Old Mar 19, 2003 | 02:13 PM
Spunkster's Avatar
look at the instuctions for installing the supercharger. It also will tell you how to tension the belt. you need to check the crank to alternator belt and the alternator to blower belt.
HondaTeKnology
Aug 17, 2009 11:25 AM
SpoonyDC5
Dec 30, 2006 08:34 AM
sr20dettrex
Jan 13, 2004 07:02 PM
Rory Breaker
Jun 1, 2003 03:08 PM
