Help d16z6 arp headstud install?
Old May 15, 2005 | 09:16 AM
booscivic's Avatar
Default Help d16z6 arp headstud install?
I have a d16z6, Im putting my head back and one of the headstud stick out longer than the other ones. The holes have been clean and air, the stud have been installed the right way is this normal? is the one to the far left corner
Old May 15, 2005 | 09:56 AM
s2kdre's Avatar
Default Re: Help d16z6 arp headstud install? (booscivic)
arp recommends re threading the holes, so that stud probably didnt go all the way down
Old May 15, 2005 | 10:08 AM
TurboGoKart's Avatar
Default Re: Help d16z6 arp headstud install? (jdmhonda)
What is the part number of the box of ARP head studs? There's one that says D16Y, and from what I've heard, one of those will be longer.
Old May 15, 2005 | 10:12 AM
DeadVet's Avatar
Default Re: Help d16z6 arp headstud install? (TurboGoKart)
is it the upper left corner that sticks up farther? If i remember right the upper left corner of mine sitting up a little higher because the head was higher there
Old May 15, 2005 | 10:17 AM
alpha's Avatar
Default Re: Help d16z6 arp headstud install? (1TurboHatch)
I was under the impression the upper left came out farther. I could be wrong as I dont have much experience with SOHC's. I would like to know for sure though.
Old May 15, 2005 | 10:26 AM
DeadVet's Avatar
Default Re: Help d16z6 arp headstud install? (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">I was under the impression the upper left came out farther. I could be wrong as I dont have much experience with SOHC's. I would like to know for sure though.</TD></TR></TABLE>
thats what i meant
Old May 15, 2005 | 12:45 PM
saleensolution's Avatar
its been awhile since i fooled with a single slam but it seems that there was a bolt or two that were longer. is there and of them that look like it might set to low?
Old May 15, 2005 | 01:17 PM
Enzo Speed's Avatar
Well, we-todd-did-racing just took a **** on my face, so I can't get pics up.
I tried to link pics to my z6 block with ARPs sticking out. One is definitely higher. That is normal.
Old May 15, 2005 | 01:30 PM
EJ1 wilcox's Avatar
Default Re: Help d16z6 arp headstud install? (QuagmireII)
Totally normal...
The head is thicker in the top left corner... put the head on and you will see that all of the head studs stick out the same amount above the head.
Don't be alarmed. I thought it was kinda weird when I did mine until I put my head back on and realized it was okay.
Old May 15, 2005 | 02:58 PM
booscivic's Avatar
THanks for the help, is normal
Old Dec 18, 2007 | 03:42 PM
methos713's Avatar
Default Re: (booscivic)
old thread, but glad it was here to help me. Just installing my arp into my z6...I was stump when the far left one was higher.
EG-SIXV-TEC
Aug 10, 2013 02:08 PM
ghettocrxsi
11
Apr 23, 2003 03:41 PM
