Help!! Coolant issue !!
Old Jul 9, 2009 | 08:06 AM
jksmith's Avatar
Default Help!! Coolant issue !!
I have a built LS/Vtec, b18b w/ b16 head.
I just changed my Headgasket and installed a breather setup, using a Freeze plug in the hole where would be on the PCV black box and, -10 port on the back of the block, and capped off the other line that went to the pcv box!
that is all i changed with the motor and had no problems before..
I used a OEM B16 headgasket !
problem is Coolant is draining and mixing with the oil as fast as i can poor it into the radiator? Its going str8 thru the block and into the oil pan!!
Anyone have any idea as to why?
Ls-VTECda9
Jul 6, 2015 11:48 AM
YuJin
Oct 30, 2011 02:21 PM
jksmith
Jul 9, 2009 02:33 PM
mtownsi
Apr 25, 2007 07:56 AM
skunk2finatic
Dec 16, 2004 02:46 PM
