Help choosing head gasket..
Old Aug 21, 2009 | 07:27 AM
JdmTypeRdc2's Avatar
Icon2 Help choosing head gasket..
Hey guys, i need some help choosing my headgasket for my gsr turbo build. I rely on you guys, since it will be my first turbo motor, and yea, you can say i went all out on this. I wanted it to be a very reliable street car and maybe will see the track once a year for 5 or passes each time. Mostly it will be driven on the street tho, so looking for a headgasket that will be of good quality and last me awhile.
I know about the OEM reliabilty, and golden eagle's modified OEM gaskets, but im still a little confused, so i will post my setup and hopefully you turbo gurus can help me out a little...
block
GSR block
Benson 83mm sleeves
CP pistons 9.0:1
Manley I beams
ACL bearings
Block was slightly decked for smoothness and straightness.
Head:
GSR head
Stock GSR cams
ITR valve springs & Retainers
Ferrea 6000 Valves
OEM valve seals
Ferrea Bronze valve guides
Skunk2 Manifold w Hondata gasket
Head is built by Headgames and was slightly milled for smoothness and straightness
Now, according to the Zealworks compression calculator, im looking at about 9.1:1 compression i believe. Can you guys confirm this?
With a stock .030 headgasket, I would keep the compression at that, but i would like to be at 9.5:1 or 9.6:1 to make it a little more streetable and responsive at lower rpms.
Is this a good idea? To want to up the compression? If so what headgasket would i need...obviously a custom 83mm bore would be needed, but im not sure about the thickness or where to find it.
Unless you guys can convince me otherwise, that this 9.1 or 9.2:1 compression would be worth it for the street...
Turbo will be a Garrett 57 trim, .63AR...
I want a quick spool and good power...
Any help would be greatly appreciated...
Old Aug 21, 2009 | 03:19 PM
honda4g63T's Avatar
Default Re: Help choosing head gasket..
o ring the block and l19's any head gasket
Old Aug 21, 2009 | 06:45 PM
No need for o rings on benson sleeved blocks...
I was looking at just removing the middle layer of the oem head gasket, bringing it from .030 to .020, therefore increasing compression by about .3 or so...putting me right around 9.5:1
Old Aug 21, 2009 | 06:49 PM
SilverEk3dr's Avatar
OEM FTW.. & just put it on there the way it was intended.
Old Aug 22, 2009 | 05:43 AM
I guess the only company i can go with is Golden Eagle, as they are the only ones that seem to make bigger bore OEM hgs.
Buddy club, spoon, mugen, etc all make standard bores, which would do me no good and the price is crazy...
Old Aug 22, 2009 | 05:59 AM
Rdriver's Avatar
I used a cometic on my last build. You can get any bore or thickness.
Old Aug 22, 2009 | 06:07 AM
Yea ive been looking into Cometic as well, and i know they are of good quality...But i think the thinnest size they make is .027 which is almost like stock right?
If they would have made a .020 i would have jumped on it.
superiorx120
Jul 16, 2011 06:30 AM
EG6 Love
Oct 15, 2009 03:22 AM
suno
Oct 7, 2008 07:36 AM
boosted_igor
Jun 26, 2007 09:22 AM
xyzalvarez
Dec 1, 2005 11:13 PM
