Help. Which CC clutch do I have?
Old Feb 26, 2009 | 02:43 PM
m R g S r's Avatar
Default Help. Which CC clutch do I have?
So you can't trust anyone or anything bought from b20vtec.com. I bought an "B series Hydro ACT 6 puck clutch" from a member on there.
It's not ACT. I'm pretty sure its Competition Clutch, because on the Disc there are two C's back to back.
But I'm not sure which one it is. If I remember correctly, all CC clutches come with the same pressure plate, so I'm not worried about that. But the clutch disc is what I'm worried about. It's a 6 puck, and there are dual springs in it. Going by what CC's website says, the only 6 puck sprung disc with dual springs is the Stage 4 - Strip Series 1620 Clutch Kit .
I just want to make sure its not the stage 1 clutch kit, because that is not strong enough for FI (Going turbo LS, prob aroung 300whp).
So do any other discs have dual springs, or is the stage 4 the only one with dual springs? And am I correct in thinking all the PP's are the same? Thanks guys
Old Feb 26, 2009 | 02:48 PM
RedneckRicer's Avatar
Default Re: Help. Which CC clutch do I have?
Pictures will help. from your description i can name about 30-40 clutches..lol
Old Feb 26, 2009 | 05:10 PM
m R g S r's Avatar
competition clutch makes 30-40 b series hydro 6 puck clutches? That's a lot! :p
Old Feb 26, 2009 | 05:12 PM
no there is prolly 30 companies out there that make a 6 puck clutch for a B series.
Old Feb 26, 2009 | 05:16 PM
narfdanarf's Avatar
Mine started to slip around 300 ft. lbs of torque and 400whp, I am pretty confident that it would have held more but I think it might have got fluid of some sort on it and ruined it.
Old Feb 26, 2009 | 05:51 PM
m R g S r's Avatar
I narrowed it down to a competition clutch by the back to back C's stamped on the disc as I said in the title and post.
Which clutch started to slip? The stage 1 or 4??
Old Feb 26, 2009 | 05:59 PM
squeezedeghatch's Avatar
is there a part number on it, that would help. You could also try calling a dealer or Competition Clutch and ask them. They would probably know best
EDIT:https://honda-tech.com/forums/performance-45/competition-clutch-sale-2140621/
try narrowing it down, there are a whole list of CC clutches. look at the actual contact surfaces, they seem to be different
Old Feb 26, 2009 | 06:08 PM
m R g S r's Avatar
No part numbers
Old Feb 26, 2009 | 06:48 PM
narfdanarf's Avatar
The competition clutch sprung 6 puck which is the stage 4 is the one that slipped on me at 400whp and 300tq
Old Feb 26, 2009 | 09:01 PM
m R g S r's Avatar
It's hard to tell by the contact surfaces, it's used so the color is probably off from when it was first purchased.
BrianB16A2
Nov 3, 2013 07:20 PM
tban21
Jul 19, 2008 09:11 PM
DAintegra1
Nov 3, 2007 08:06 AM
Mr.Luder
Sep 18, 2007 02:20 PM
spooncivic1
Apr 25, 2005 10:13 AM
